Cabot Stains W/ No VOC Over Old Cabots
Old 03-17-2009, 10:53 AM   #1
Green Guy 58's Avatar
Trade: Foundation Waterproofing and Painting
Question
A house we recently Stained during mid summer with Cabots No VOC semi solid Stain now has black mold all over it. Everywhere. History. In 2000 the new cedar clapboard siding was stained with Cabots oil based-semi-transparent stain on both sides. After 7 years, siding was very dry with little stain visable. During a hot spell in July of 07, temps around 80-90, we restained it with 2 coats of the new Cabots semi solid with no VOC's using a Wagner Spayer and back brushing. During this winter (08-09) the house became covered every where with this black wet mold. Even where there is alot of sun.
Has anyone ever experienced this? And do you know of a solution. Cabot is of no help.
Green Guy 58
Green Guy 58 is offline
Old 03-17-2009, 11:48 AM   #2
NAV's Avatar
Trade: commercial building restoration
Re: Cabot Stains W/ No VOC Over Old Cabots
WOW that sucks. can you tell if the mold is growing on the semi-trans stain or if it is coming from under the material you applied (did you apply over a wet surface and did you wash the house properly?)?
It sounds like you need to talk to a Microbiologist. sometimes materials have mold and bacterial growth in them from the factory. This is something you need to get your paint rep involved in.
NAV is offline
Old 03-17-2009, 03:47 PM   #3
The mold is on the outside of the stain and you can actually wipe it off. The stain was put on the house when it was hot and dry. The siding just sucked it right in quickly. I explaned it to Cabot and their answer was that we had a lot of rain the past two years which made everything get moldy and musty. I've just never seen anything like this before. Don't make sense.
Old 03-17-2009, 03:56 PM   #4
Allrounder Home Services
EricTheHandyman's Avatar
Trade: Painting, Remodeling, Handyman
Are you positive that it's mold? Are there other homes in the area with this sort of a problem?
EricTheHandyman is offline
Tags
cabots, mold, stain
Stains in Pool (Pictures included) Sir Mixalot Pool Construction & Enclosures 25 05-03-2010 09:50 PM
first time using stains VoodooSteamBoat Painting & Finish Work 4 09-05-2008 01:03 PM
Water-based stains cinder11 Flooring 0 08-14-2008 07:06 PM
Rust and other stains on limestone.. ruskent Masonry 1 06-16-2008 11:06 AM
PW Kool Deck with water stains MinConst Pressure Washing 9 08-29-2007 03:13 PM
