Central Building Finish
Trade: paint
Cabinet Laquering Pricing recently got a job to do several tract houses. these guys did not buy finished cabs. they want them laquered or poly. any ideas on price and what might be quickest and still get a nice finish.
MFWIC
Trade: house painter
Re: Cabinet Laquering Pricing
we did a large new spec w unfinished birch cabs in poly w hvlp.
Had no other work at the time... WAY underbid it. I would say labor is 3-4 times more difficult once installed than when in the shop. ... Only a cheapskate of a general would buy unfinished cabs, trying to save a few cents... then try to grind on the ptrs to finish them later. As you figure your bid, carefully consider the time involved in EACH step, as they will ALL be very time consuming, labor intensive, and require precision & cleanliness. r Last edited by Tmrrptr; 08-26-2007 at 01:57 PM. |
Trade: Painting contractor residential repaints/new construction
Re: Cabinet Laquering Pricing |
Trade: Professional Painting Contractor
I have always had a hard time spraying any type of clear coat or varnish I usually use a brush or roller to lay it off. If you have an hvlp you would be ok. Hvlp is the way to go.
House Painters Commercial Painting Contractors Cleveland, Ohio http://www.welovepainting.com http://www.cleveland-ohio-painting-contractor.com |
27yrsPaintandFinefinishes
Trade: paint talk
In answer to your question I get $50-55 per linear foot. Top cabinets (over counter) are measured seperately. I use top quality pre-cat lacquer 2 full coats of sealer and minimum of 2 full coats of lacquer. All sprayed with an airless. I never use poly as the drytime is not condusive to furniture quality finishes.
Don't believe the hvlp hype unless you have all day they are not for production work. I'll have to find pictures of the $67,000 set of cabinets that I stained and lacquered. My bid was $11,657. All of them came out furniture quality. Rick Last edited by Runamuk; 08-27-2007 at 02:00 AM. |
| Cabinet Instal pricing | twstrcutures | Finish Carpentry | 7 | 04-26-2007 11:17 AM |
| Pricing for Dallas area??? | TexSeal | Painting & Finish Work | 2 | 02-22-2007 01:15 PM |
| Any other New Englanders in here..Pricing???? | Red Hat | Finish Carpentry | 0 | 08-21-2006 10:53 AM |
| custom cabinet pricing | smadercarpentry | Finish Carpentry | 4 | 06-06-2006 05:24 AM |
| Cabinet Pricing | KRP | Carpentry | 12 | 02-12-2006 11:06 AM |
