Trade: Flooring contractor
Brush Or Spray Lacquer
I have a project with about 19 doors that I need to stain and finish, and have been debating on whether to brush on the lacquer or break down and buy an HVLP sprayer. I have been looking at the spraytech 9100, 9900, and the Graco Procomp 4900. Does anyone have any advice for me on which way I should go. Brush or Spray? Which HVLP setup?
Thanks |
Thom
Re: Brush Or Spray Lacquer
Lacquer dries to fast to do a good job with a brush on a large surface like a door. Spray it.
Organic Painter
Trade: Painting Contractor
I think on the can it says spray only...
Organic Painter
Call a painter...
Perhaps I should have mentioned that I previously worked in a cabinet shop and have some experience spraying with high pressure systems, but i no longer work there. Now I need to either invest in a HVLP system which I am not as familiar with or brush the lacquer which I have never done and am not completely comfortable with. Just looking for advice from those who have done both and a possible recommendation on the sprayers that I have listed. I don't want to drop $1200 dollars on a HVLP system (which has been my plan, but I am willing to consider other options) and then find out that the other system was better.
Thanks |
Organic Painter
Rent one, you only have 19 doors, this is a no brainer on to buy or not to buy.
#7 | |
solar guy
Trade: solar contracting
Re: Brush Or Spray LacquerQuote:
![]() I always used it in a shop with a spray booth but if you don't have one off those you will need to do this outside with the bugs dust etc. Why not use a water based urethane which dries quickly and if you use a floor type finish will be durable. |
vandy
Trade: painting, decorating, wallcovering
hvlp spray.....period.
i don't care if you rent or buy. i love my Graco 4900 procomp that I got on craigslist for $200. |
| The Following User Says Thank You to vandyandsons For This Useful Post: | NJPainter (12-02-2009) |
LRG WoodCrafting
A "painter" does not use lacquer, a finisher does.
#10 | |
Organic Painter
You can always rent an airless w/ new lines. Put a 517 tip w/ a fine filter.
Trade: Painting, flooring
Yeah, I did some stain grade trim with laquer top coat with an airless last year and it turned out very nice. Did it in my shop. Made sure to smoke OUTSIDE. JK
A bit abrasive.
the title of this thread is ridiculous.
My advice: Hire a real painter to do it. |
Trade: paint and drywall
Spray lacquer only. If you have never sprayed it before, don't try it on your own.
Project Manager/Carpenter
Trade: Carpentry/Reno
...when I spray I do it using an HVLP gun....
I use this, but I put a metal cup on it. |
Built 4 cabinets last month and used the cabots brush on laquer with good results. It was the first time I had used it.
I poured some in a seperate can to use and avoided wiping my brush in the same can I was using. Foam type brushes suck for it though...goes on good, but come back to a panel after finishing another and a gazzion little bubbles were there.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan |
Trade: Painting-Drywall-Restoration-Pressurewashing-
Re: Brush Or Spray Lacquer |
#18 |
#19 |
Trade: Commercial Painter
Lacquer has a very low flash point. I met a guy who was a surviving burn victim: his helper plugged in a cord, and the ark caused an explosion. They where cleaning a paint spill in a swimming pool with lacquer thinner.
You will have a better profit margin to sub it out. |
#20 |
House Painting Denver
Trade: Painting, Painter, Painting Contractor
I would recommend spraying the doors. Not only will it look a lot better with spraying, but it will go a lot faster too! No brainer: Save Time & Money!!! That is always best. But I also agree that you should rent one for this project. You can rent an HVLP for a day for around $100 per 24 hour period.
| Cabinet finishing with Lacquer | sclancy | Painting & Finish Work | 3 | 05-02-2009 08:43 AM |
| Production rates for rolling, brush, and spray also stilts | plazaman | Painting & Finish Work | 8 | 11-14-2007 03:28 PM |
| spray, brush, or roll doors? | Traditions | Painting & Finish Work | 13 | 03-31-2007 10:20 AM |
| I hate lacquer | DeanV | Painting & Finish Work | 3 | 02-01-2007 09:56 PM |
| proper way of loading of brush from a cutting pail | Zeebo | Painting & Finish Work | 7 | 08-11-2006 11:58 PM |
