Old 02-20-2007, 01:01 AM   #1
Trade: painting and pressure cleaning
brush and roller vs sprayer
is it just me our does it seam like roller is faster. because of the clean up of the airless sprayer?
Robert S is offline   Reply With Quote
Old 02-20-2007, 01:06 AM   #2
My custom title
Brushslingers's Avatar
Depends on the job, if the square footage is over a certain amount, I will spray if possible. But yes, on an average repaint breaking out a sprayer isn't faster.
Benn
Originally Posted by Brian
Brushslingers is offline   Reply With Quote
Old 02-20-2007, 06:51 AM   #3
Traditions's Avatar
Trade: painting
new construction sprayer. Almost never use sprayer on repaint. I spray my ceilings and primer then roll everything else. How many people spray finish coats? Do you shield your ceiling lines or stay about 6 inches down then brush in ceiling lines.
Traditions is offline   Reply With Quote
Old 02-20-2007, 07:14 AM   #4
shield but then its a hassle to wash off shield.in the past i have used masking paper also.
Old 02-20-2007, 08:05 AM   #5
Frankawitz's Avatar
Trade: Plastering, Drywall, Painting, Woodworking, Stucco, refinishing woodwork
The only time I use the sprayer is outside. Just because of the over spray on the inside is to much to control. and beside you get better coverage with a roller then you would ever get with a sprayer. My customers want a top quailty paint job not a blow and go job . I have seen other companies use the sprayers and for all the masking and then the clean up I could roll the place out and be done while they are still clean up their mess. I guess I'm old school.
Frankawitz is offline   Reply With Quote
Old 02-20-2007, 09:35 AM   #6
Painter
camaroman2125's Avatar
Trade: Painter
Repaints its the old brush and roller. New construction I break out the sprayer and back roll ceilings and walls. Since there really isn't anything in the new constructions over spray really isnt' a issue. Everything is usually one color in the new constructions if it is a spec so we do ceilings and walls at the same time.
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
camaroman2125 is online now   Reply With Quote
Old 02-20-2007, 01:25 PM   #7
Workaholic's Avatar
Trade: Painting Contractor
New construction, Spray ceilings and trim,
Repaint roller and brush, if you have a completely empty room and have a ceiling to spray, then i would pull out the sprayer.
Workaholic is offline   Reply With Quote
Old 02-20-2007, 01:37 PM   #8
mustardseed
I use my spray machine as much as possible. Walls, ceilings, baseboards, crown molding, cabinets.
mustardseed is offline   Reply With Quote
Old 02-20-2007, 02:42 PM   #9
same here only time i have used it indoors was at customer request the carpet was being replaced so he suggest to blow and go.normaly i use it outdoors bbut im like you it seems better with roller
Old 02-21-2007, 01:32 AM   #10
Jonesey's Avatar
Trade: Painting and Finishing
I do a lot of custom finishes so I can't live without a sprayer, but on walls or ext. the only time I'll run a sprayer is new construction, then I backroll with an 18". Super fast, and better finish than spray only.
Steve Jones
steve@jonespaintingonline.com
Jones Painting Feel the difference service makes
Jonesey is offline   Reply With Quote
Painted My Truck With a Roller ModernStyle Painting & Finish Work 44 07-21-2007 09:11 PM
Titan power roller... My first impressions steve-in-kville Painting & Finish Work 0 06-17-2007 10:22 AM
What size roller covers? metomeya Painting & Finish Work 10 11-28-2006 06:48 AM
Just a roller! yikkle Painting & Finish Work 8 07-21-2006 05:20 AM
To brush or roll Painters Plus Painting & Finish Work 14 05-03-2006 08:44 PM
