Brush And Roll Or Spray - Painting & Finish Work - Contractor Talk
Old 10-12-2017, 03:30 PM   #1
CeRoy's Avatar
Trade: Handyman
Rewards Points: 4
Painters,
I'm painting 2 rooms in an old house. Both are kind of funky with curved ceilings, multiple windows with victorian trim plus odd shaped closets that will be painted. This is a lived in house, but of course rooms will be emptied out for painting. Just wondering best way to go about this and how to decide between brush/roll and spraying. Do some of you ALWAYS spray? Is it generally worth it to go through all the work of masking since spraying is so fast. Each room is 2 colors, one for walls and one for trim.
Spraying question-how do you handle the overspray that gets in the air? Open a window, completely tarp the floor? Should the door to the room be sealed with tape so overspray does not float to other areas of the house?
I haven't done enough painting to own a sprayer but will consider it for this job and future jobs.
Thanks for your insights!
C
CeRoy is offline
Old 10-12-2017, 05:50 PM   #2
avenge's Avatar
Rewards Points: 3,226
Re: Brush And Roll Or Spray
It's 2 freakin rooms. You plan on spraying all ceilings, walls and trim? If you don't have experience spraying and masking you shouldn't be learning in an occupied victorian house at the homeowners expense.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
EC Painter (10-17-2017)
Old 10-12-2017, 08:40 PM   #3
CeRoy's Avatar
Trade: Handyman
Rewards Points: 4
No worries, have used a sprayer many times, not so much on interiors except for remodels and a pressed tin ceiling where it worked absolutely perfect but had to mask the entire room.
I'll rephrase the question...
At what point would you choose to spray interior rooms (with architectural details) in an occupied home? (Maybe it's never)
Thanks
CeRoy is offline
Old 10-12-2017, 08:47 PM   #4
VinylHanger's Avatar
Rewards Points: 8,336
I'd roll and brush. By the time you tape and mask all the detail work, then retape the walls or trim, you could be done.
VinylHanger is online now
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
CeRoy (10-12-2017), KAP (10-12-2017)
Old 10-12-2017, 09:55 PM   #5
hdavis's Avatar
Rewards Points: 3,925
Sometimes just spraying fancy trim makes sense. The question is always what's going to be the fastest way to get the results you're looking for. On a single room, spraying setup and clean up is going to eat your lunch, but it isn't out of the question for 2 rooms with fancy trim, etc.
If you just spray ceiling and trim, there isn't much masking involved. Spraying walls around fancy trim may need a lot of masking....
How fast can you roll and cut, vs mask and spray?
hdavis is offline
CeRoy (10-13-2017)
Old 10-12-2017, 10:50 PM   #6
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,880
Mask the floors and glass, spray trim, brush and roll everything else. Generally the fastest way to do it.
FFLP tip, close off the room you're in, good spraying technique can limit overspray.
Golden view is online now
CeRoy (10-13-2017)
Old 10-12-2017, 11:04 PM   #7
LU'Plaster's Avatar
Trade: Plasterer/ Painter
Rewards Points: 8
Originally Posted by CeRoy View Post
Painters,
C
if the rooms will be empty and you want to invest in a good sprayer buy a graco true coat airless sprayer, easy to clean easy to start easy to unclog, just have to have at least 4 paint containers for the machine, spray closets, trims, and ceilings brush and roll walls if walls too curved use a thicker roller if wall is in bad shape u wont skimcoat just paint try to use flat finish will hide alot imperfection or at least a matt finish, u dont need much masking protect the floors with paper and window with plastic .. properly this is what i would do.. and this sprayer grate finish very easy coast around 250 not much over spray,worth it to me. good lucky.
LU'Plaster is offline
The Following User Says Thank You to LU'Plaster For This Useful Post:
CeRoy (10-13-2017)
Old 10-17-2017, 04:19 AM   #8
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
we would brush and roll that job.
DiaperRiot is offline
Old 10-17-2017, 05:29 AM   #9
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,538
I rarely consider interior spraying in occupied homes.
Ohio painter is offline
The Following User Says Thank You to Ohio painter For This Useful Post:
ScipioAfricanus (10-17-2017)
Production rates for rolling, brush, and spray also stilts plazaman Painting & Finish Work 14 10-21-2017 06:18 AM
Roller Marks and Brush Marks michaelsaam Painting & Finish Work 0 02-28-2011 08:49 PM
spray, brush, or roll doors? Traditions Painting & Finish Work 13 03-31-2007 09:20 AM
spraying has ruined my brush and roll estimating Traditions Painting & Finish Work 11 09-15-2006 03:31 PM
To brush or roll Painters Plus Painting & Finish Work 14 05-03-2006 08:44 PM
