To Brush Or Roll
Old 04-26-2006, 09:14 PM   #1
Painters Plus's Avatar
To Brush Or Roll
Just wondering if all you painters brush or roll doors and garage doors. I read once all woodwork and doors should always be brushed. I know if I paint a steel garage door with a brush it looks different than if i used a roller. What is the correct way here?
Painters Plus is offline
Old 04-26-2006, 09:41 PM   #2
George Z's Avatar
Trade: Painting Contractor
Re: To Brush Or Roll
There is no correct way, it depends which look you or your customer wants
George Z is offline
Old 04-26-2006, 10:06 PM   #3
phinsher's Avatar
Trade: Paint and wallpaper
I agree with George. If it's been previously painted I'll usually stick with the previous application method. Living in an older area most people here tend to like the brushed look on trim and doors.
phinsher is offline
Old 04-27-2006, 12:59 AM   #4
Woz the Painter's Avatar
Around here, all high-end residential trim gets painted by brush, weather it's interior or exterior. Interior can be rolled on and layed off with a brush, but you must use a foam wizzy, no lint or hair allowed. Exteriors you can have a fuzzy roller and lay off with a brush. But if it's already been rolled, what difference does it make?
Woz the Painter is offline
Old 04-27-2006, 09:10 AM   #5
Painting Contractor
Humble Abode's Avatar
Send a message via AIM to Humble Abode
Are you talking raw wood or repaints?
I think the idea behind brushing raw wood is to work the primer into the pours. That can be acheived with a roller too. I usually brush and roll doors, especially if I have more than one.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 04-27-2006, 12:27 PM   #6
Peter B's Avatar
I usually spray all my doors, it leaves a perfect finish everytime, no brush marks and faster if there are a lot of doors.
Peter B is offline
Old 04-27-2006, 03:17 PM   #7
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
I am with you , I spray all my doors, especially if there are more then one...
painterofeveryt is offline
Old 04-29-2006, 06:49 PM   #8
Does this include inside doors in occupied homes or offices? Seems like masking, covering furniture etc. would negate any time savings from spraying!
Old 05-03-2006, 08:36 PM   #9
Painting Contractor
If you're going to spray a door you have to take iot down and take it somewhere to be sprayed. If you're lucky it's your shop or garage. Otherwise the back yard and some tarps will do...
The NAPP
Old 05-03-2006, 08:54 PM   #10
SAy your doing an office repaint, occupied office, that has 40 doors and frames, would you take them all off, load them on your truck, take them to your shop spray them, haul them back and rehang them? Or just take and brush and roll them with a mohair sleeve?
Old 05-03-2006, 08:59 PM   #11
Painting Contractor
Yes. It's great you can smoke and swear. You're not anywhere near a cubicle, and you can spray which is easier that brush/roll all round.
The frames i would brush...
No Unless I had 5 or more employees.
The NAPP
Old 05-03-2006, 09:12 PM   #12
You can still smoke and swear in some offices, and sometimes their is unbelievable scenery around, if you know what I mean!
Old 05-03-2006, 09:15 PM   #13
Painting Contractor
I guess it would have to come down to transport. At the moment I would have trouble transporting 40 doors without renting a trailor... And I am sure not emptying my van.. I can barely bring myself to clean it.
Ideal situation for spraying these 40 doors, for me would be to lay tarps and spray them in the parking lot.
Do you have 40 doors to paint or is this just a hypothetical? Not that it matters...
The NAPP
Old 05-03-2006, 09:36 PM   #14
I've done hundreds of jobs with 40 or more doors to paint and many times spraying is not an option. If you know how to brush and roll them, they look great, and you'll take less time than taking them off, moving them, spraying them, rehanging them, plus when your dealing with doors that weigh over a 100 pounds, your back will thank you. I worked on the new International Terminal at O'hare in the early 90's, we brushed and rolled over 1800 doors and frames, 3 coats
Old 05-03-2006, 09:44 PM   #15
Painting Contractor
How long did that take? When you finished the last one did the first need repainting?
The NAPP
Brush filaments? gideond Painting & Finish Work 7 06-21-2007 06:58 AM
spray, brush, or roll doors? Traditions Painting & Finish Work 13 03-31-2007 10:20 AM
spraying has ruined my brush and roll estimating Traditions Painting & Finish Work 11 09-15-2006 04:31 PM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 11:58 PM
a brush or roll dilema izote61 Painting & Finish Work 7 10-02-2005 09:32 AM
