Bringing Out The Grain....
Old 07-17-2006, 11:43 AM   #1
prolinefinishes's Avatar
Trade: Painter/Sub-Contractor
Got a room that is trimmed in poplar, it is getitng stained a drakish red/brown. problem is i need the grain in the wood to stick out more. It doesnt show very well and it needs to. What do i need to do, conditioner, paint, anique?
Also, i need to bring out a dark edge in areas where there is no grain, like at the lip of the trim. I was thinking rough sand and stain it will be darker in that area.
Any suggestions are greatly appreciated
Steve
prolinefinishes is offline
Old 07-17-2006, 12:17 PM   #2
Exroadog's Avatar
Trade: paint
Re: Bringing Out The Grain....
Poplar has no grain to speak of. Usually if used, in my area, its painted.
Exroadog is offline
Old 07-17-2006, 12:54 PM   #3
poplar, and has grain, but very little. Enough that it would look nice if i could bring it out.
Old 07-18-2006, 07:37 AM   #4
Jonesey's Avatar
Trade: Painting and Finishing
The actual pores in poplar are very small. Poplar is what most call a 'closed-grain' hardwood. What most people refer to as grain is the actual pores. The grain in oak, for instance, is simply the longitudinal pores. If it has pores like oak, but is green like poplar, it's likely swamp ash, not poplar.
If you want to enhance the color of poplar and have already stained it, I would suggest using a color deck to pick out which colors I wanted to enhance and get them mixed in a glaze. Glaze over the top of two coats sand n seal, one coat finish.
Process would look like this:
raise grain
presand
stain
2x sand n seal
putty
sand
1x finish
glaze 1 color
wait 2 days
glaze 2 color
wait 2 days
2x finish
It's important to put a finish over your putty or it will take the color of the glaze. It's also importan to wait long enough for the glaze to dry before applying a finish over top of the glaze. Wet finish will pull a mostly dry glaze right off your trim and make an ugly mess.
You will probably want to apply the glaze in a 2 brush method to soften the edges of the color where you want to enhance it.
You can also do this with stain during the staining phase. Simply apply by brush and pull off with a dry brush, adding and removing as you see fit until your product meets your needs. However, that is generally only of use when you want to color the wood and cover the grain.
Steve Jones
steve@jonespaintingonline.com
Jones Painting Feel the difference service makes
Jonesey is offline
Old 07-18-2006, 09:46 AM   #5
Peladu's Avatar
Nice info Jonesey
Peladu is offline
Old 07-19-2006, 07:13 PM   #6
Yes awesome info. Hopefully i can use it for future purposes, because the GD homeowner changed their mind again!!!!!!
Old 07-20-2006, 07:46 AM   #7
Jonesey's Avatar
No prob. I'll expect my royalty check in the mail.
Steve Jones
Jonesey is offline
Treating end grain joints Chris G Decks & Fencing 12 12-03-2009 07:54 AM
Problem with sap oozing out of wood grain saucedo80 Painting & Finish Work 6 08-04-2007 02:22 PM
Grain bins and metal buildings Traditions Painting & Finish Work 7 02-01-2007 10:43 AM
hollow grain doors boman47k Painting & Finish Work 11 11-16-2006 11:07 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
