Had to search to see what this effloresence that you speak of was....
Found this, might be helpfull.....
Protecting Against Efflorescence
It is possible to protect porous building materials such as brick, tiles, concrete and paving against efflorescence by treated the material with an impregnating, hydro-phobic sealer.This is a sealer which repels water and will penetrate deeply enough into the material to keep water and dissolved salts well away from the surface.
Efflorescence can often be removed with diluted phosphoric acid (usually about 1 part acid to 10 parts water, but follow the directions on the bottle). Always test some of the acid solution on an inconspicuous area first to ensure it will not discolour the surface material. The acid dilution should then be neutralised with mild diluted detergent, and then be well rinsed with water.
The source of the water penetration should be addressed. If the water source is groundwater or faulty flashing the efflorescence may reappear, unless properly sealed.
