Block Paint
Old 10-29-2006, 07:29 AM   #1
GC/ Master Electrician
Ken@K&R's Avatar
Trade: General Contractor/ Master Electrician
Send a message via AIM to Ken@K&R Send a message via Yahoo to Ken@K&R
Block Paint
Anyone able to recomend a good quality block paint? Our office is needing paint real bad but im not a fan of heights and such. Really would rather not have to do it over every 6 months.
TIA
Ken
Ken@K&R is offline
Old 10-29-2006, 08:16 AM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Block Paint
What is 'block paint'?
ProWallGuy is offline
Old 10-29-2006, 09:38 AM   #3
Painter
camaroman2125's Avatar
Trade: Painter
Re: Block Paint
Maybe it the paint they use to paint the little wood blocks with numbers and letters on them that my kids like to throw at each other.
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
camaroman2125 is offline
Old 10-29-2006, 09:45 AM   #4
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Block Paint
K & R's new office is in a bad neighborhood, so he want's to paint the whole block. You know, try to improve the neighborhood!
But he doesn't want to do it every 6 months, for fear of being hung from a tall tree. since he's afraid of heights & the neighbors don't want increased property taxes.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread.
maj is offline
Old 10-29-2006, 09:56 AM   #5
Mike Danahy
Danahy's Avatar
Trade: Signature Painter
Re: Block Paint
Not sure what it's called, maybe it's called Block Paint? There's this display setup at some of the different suppliers, where a block is half paint with white block paint, and the display has a continuous stream of water flowing around it. Next time I go I'll actually look, but perhaps someone else knows that display I'm talking about. I only have seen it at General Paints, but never paid much attention as they are my sundry supplier.
Danahy is offline
Old 10-29-2006, 09:59 AM   #6
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Re: Block Paint
It's a type. He meant black paint, perfect color for an office
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 10-29-2006, 10:19 AM   #7
Frankawitz's Avatar
Re: Block Paint
If your having to repaint every 6 months maybe you need to remove the old paint, Here's what we do when we have new block to paint use Benjamin Moore's Block Filler, this stuff is designed to soak into the block that way when you paint your finish it doesn't get sucked into the block. another thing is if you have water speeping in then you need DryLock paint this will stop any moisture, then when you paint it will last longer then 6 months.
Frankawitz is offline
Old 10-29-2006, 10:30 AM   #8
Woz the Painter's Avatar
Re: Block Paint
Are we talking about block or CMU's???
Woz the Painter is offline
Old 10-29-2006, 11:05 AM   #9
Ken@K&R's Avatar
Re: Block Paint
guess I should have said masonary paint
Ken
Ken@K&R is offline
Old 10-29-2006, 01:48 PM   #10
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
Re: Block Paint
masonry paint...made by a company called maxxum (owned by coranado)is called blocklustre check it out,great stuff !!!
painterofeveryt is offline
Old 10-29-2006, 02:42 PM   #11
My custom title
Brushslingers's Avatar
Re: Block Paint
I always used Duron block filler, works great... but hey, whatever is in your neighborhood.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 10-29-2006, 03:53 PM   #12
Joewho's Avatar
Trade: Painter
Re: Block Paint
Frankawitcz has given the right info for you.
Block filler is made for cinder block and such. You can do a search for block filler, read the specs and find out which one will last the longest.
there are also elastomeric paints, which we use on the new condo exteriors. It is really, really thick. You can search that out too, it may be what you're looking for.
Joewho is offline
Old 10-29-2006, 04:10 PM   #13
Miniroller's Avatar
Trade: Painter
Re: Block Paint
I watched a painter I used to work for take a tube of dap painter's caulk and add it to one gallon of paint ( i think it was BM superhide eggshell). Curious as I was, he told me it was for filling the little holes on concrete blocks so you paint and fill in same coat.
Miniroller is offline
Old 10-29-2006, 05:42 PM   #14
stacker's Avatar
Trade: masonry
Re: Block Paint
im not a painter,but i play one on tv. anyway,we have always recommended porter flex by porter paints.
stacker is offline
Cinder Block walls, block filler and a leak...question SeanATL Painting & Finish Work 9 03-09-2009 04:33 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
blistering paint GWHRsuperhero Painting & Finish Work 9 03-06-2007 08:43 PM
