Blistering Paint
Old 04-13-2009, 07:21 PM   #1
twilson's Avatar
Trade: general contractor
Blistering Paint
I am working in this house. The painter is having trouble with the paint blistering. It is a 1960's house. All the prep work has been done well. The nail pops are filled with drywall compound and sanded down. Some walls are primed to seal up the pop marks. The other walls that do not have pops are not sealed. The paint is aura (Benjamin Moore). Home owner insists on this paint. the room is cool 55 degrees when we are painting.
The problem is that the wall are blistering with in one hour of painting the walls some blisters are 1/2 inch to 1/8 inch in size. Sometimes where the drywall pops are fix other times no where near a fixed pop.
The painter has contacted the 1-800 number & no good answer. The local retailer also has no good answer.
Is there anyone out there that has experienced this problem and has a solution?
twilson is offline
Old 04-13-2009, 11:10 PM   #2
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
Re: Blistering Paint
You need to have the Ben Moore rep come out and see if there is moisture in the wall with that fancy gauge they use.
Mr. Mike is offline
Old 04-14-2009, 02:13 AM   #3
sparehair's Avatar
Trade: Painting, flooring
One thing to consider is that ambient room temperature is supposed to be about five degrees higher than the actual substrate (so sayeth the sherwin rep). Obviously this wouldn't apply if sun was directly shining on the surface.
sparehair is offline
Old 04-14-2009, 10:37 PM   #4
twilson's Avatar
thank you both for your help. the room heat was turned off and the air temp. may have been colder than the wall.
twilson is offline
Old 04-14-2009, 11:32 PM   #5
BMAN's Avatar
Trade: Painting & Remodeling
Seen this a few times when the paint was put on too soon after drywall, repairs made. Tiny bubbles right?
BMAN is offline
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 26 03-06-2009 03:14 PM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
blistering paint GWHRsuperhero Painting & Finish Work 9 03-06-2007 08:43 PM
Blistering Paint Eric S Painting & Finish Work 13 10-02-2006 03:27 AM
