Big Trim Refinish Job
Old 02-08-2018, 10:12 PM   #1
t.carpenter00's Avatar
Trade: excavating/ drywall/ currently remodeling
Rewards Points: 80
I was just invited to bid a pretty large trim refinish job. While I am a novice wood finisher with a good eye for quality, I've never attempted a job of this scale. I have a pro friend or to to bounce ideas off of. I am not going to worry about trying to get the job. I'll either get educated enough to bid it profitably, or I wont do it at all so....
An upscale 80's oak trim job with golden oak stain and lacquer on everything. There's an 18' raised panel library built in, cabinets flanking the arched mantle, fluted corners along the fireplace, 8" base, 6" crown, and 44' of wrapped headers. 33 cabinet doors, stair/ riser edging, rosettes... The works- use your imagination.
They are not meticulous people, but know the hate Golden oak (as do I)
The are going for a Jacobean stain.
They have done 1 room, and I know I can do way better. We have talked extensively about dust control, masking, etc. They know this will be expensive.
My question is : I am looking for a stain product that will MINIMIZE sanding on the out of reach areas. And a product that will be super tough for the lower portions. I am also a bit unsure of what high gloss product to put over it- poly, lacquer, alkyd, etc.
I don't think we'll be able to spray much more than the doors, so alot will be brush work.
There it is, let the games begin!
Sent from my VS988 using Tapatalk
t.carpenter00 is offline
Old 02-09-2018, 03:17 PM   #2
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,328
Re: Big Trim Refinish Job
I never take on these projects. Soooooo much detail. Sooooo much to go wrong.
Ideally you find a finish system that doesn't require you to go to bare wood. All of the fluting and coves and every thing else will drive you nuts. If it's not all sanded to precisely the same grit the stain will take unevenly. If the finish is not removed it will not take stain.
I'd do a test panel. Abrade with 180 or 220 grit. Paint one or two coats minwax polyshades. Finish with sprayed precat laquer.
Other dedicated cabinet guys might have a better semi solid color coat option.
Metro M & L is offline
The Following 3 Users Say Thank You to Metro M & L For This Useful Post:
Bull Trout (02-09-2018), sparehair (02-10-2018), t.carpenter00 (02-09-2018)
Old 02-09-2018, 04:30 PM   #3
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,194
Without the ability to spray it all, run forest run.
If you can spray, you can tone to a color change with multiple light lifts, but with a brush, I wouldn't touch it.
pinwheel is offline
The Following 2 Users Say Thank You to pinwheel For This Useful Post:
cedarboarder (02-10-2018), sparehair (02-10-2018)
Old 02-09-2018, 04:37 PM   #4
Rewards Points: 80
I was thinking that as well. I'm just unsure of spraying in a finished house.
Old 02-09-2018, 08:02 PM   #5
tjbnwi's Avatar
Rewards Points: 3,026
You'll have to spray dye toners, probably a custom blend you create.
The grain will be muted with toners.
If they want the grain smoothed out you'll need to use Aqua Coat or Crystalayc clear fillers.
Scuffing/dulling is necessary.
tjbnwi is online now
pinwheel (02-10-2018), t.carpenter00 (02-09-2018)
Old 02-10-2018, 04:59 PM   #6
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,124
Then you're not ready.
sparehair is offline
The Following 3 Users Say Thank You to sparehair For This Useful Post:
Bull Trout (02-10-2018), pinwheel (02-10-2018), t.carpenter00 (02-11-2018)
Unusual trim style? Jonbuild Finish Carpentry 7 10-25-2016 01:53 PM
Looking for a fresh idea to trim out entry door AustinDB Finish Carpentry 17 02-01-2013 02:12 AM
how should I trim out the window siding?? lewisthepilgrim Windows, Siding and Doors 24 12-02-2012 10:46 AM
Paslode Angle Trim Nailer Problem. MF Custom Tools & Equipment 3 07-16-2012 10:19 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
