Best Way To Cover Nicotine Stained Walls.
Old 11-22-2009, 11:29 AM   #1
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Hey guys. I have just purchased a house to remodel and the walls are about as yellow as they come. Woman smoked like there was no tommorow for about 30 years in the house without one coat of new paint. Do i need to pre clean the walls or can i paint straight over them with a stain blocker?
BCConstruction is offline
Old 11-22-2009, 11:39 AM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
Re: Best Way To Cover Nicotine Stained Walls.
Apply a coat of BIN shellac primer. If you want to wash them, feel free, but I don't see the need for it. Unless of course the nicotine is running down the walls, and the walls feel real sticky if you touch them.
ProWallGuy is offline
The Following 2 Users Say Thank You to ProWallGuy For This Useful Post:
BCConstruction (11-22-2009), slickshift (11-25-2009)
Old 11-22-2009, 12:17 PM   #3
Dave Mac's Avatar
Trade: Painting Contractor
Rewards Points: 688
yeap
Dave Mac is offline
Old 11-22-2009, 07:17 PM   #4
Burritos
bamawildcat's Avatar
Trade: Lectrical
Rewards Points: 27
I'm not a painter, but I used a solution of bleach and water to clean a cileing and then a coat of Kilz oil based primer, and could no longer see or smell the nicotine.
bamawildcat is offline
Old 11-22-2009, 07:22 PM   #5
Trade: Construction
Years ago i used to clean windows and we had a cleaner that would take that horrible stuff of with ease but i wouldnt know where to get that from over here. The last thing i want is that smell coming back.
Old 11-22-2009, 07:29 PM   #6
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
I disagree with "Application to Cover"...........Clean then application!
Ultimate Wisdom---------
MALCO.New.York is offline
The Following User Says Thank You to MALCO.New.York For This Useful Post:
Old 11-22-2009, 08:20 PM   #7
Trade: Construction
well i found the stuff i used to use. it's was a form of Trisodium Phosphate. will wash down everything with this before i paint just in case.
Old 11-22-2009, 08:48 PM   #8
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,292
If the walls are sticky tsp is the way to go. However you will probably run into problems if you don't scrub off the sticky thick tar. Shellac is great but the tar can bleed through even oil primer if you don't prep right. I like to rinse down the wall with tsp, then scrub with comet or other abrasive, then wipe off residue, let dry and then shellac.
Metro M & L is offline
Old 11-22-2009, 09:33 PM   #9
Remodeling Specialist
Baron's Avatar
Rewards Points: 75
Send a message via Yahoo to Baron
Wash with tri sodiumPhosphate as best as possible and it may take a few coats of a shellac based primer. I had and aunt who smoked three packs a day that we painted her ceilings with three coats of Bin and then finished. Imagine what her lungs looked like?!
Baron is offline
Old 11-25-2009, 05:23 PM   #10
...jammin
slickshift's Avatar
Trade: Rock Disciple
Ayup!!!
Signature Quote
slickshift is offline
Old 11-25-2009, 08:34 PM   #11
Toilet Maestro
lopreste's Avatar
Trade: Bathroom remodeling
I second the tri sodium phosphate. you can pickup at your local paint store or home improvement store works great and you only need a little bit. Also works great if you have really greasy, dirty clothes just add a scoop and it will do miracles.
lopreste is offline
Old 02-01-2018, 06:48 AM   #12
harmonpa's Avatar
Rewards Points: 30
The other product to maybe consider is a dry cleaning sponge prior to tsp will help save on tsp. There are a few products out there that are water based now but good old shellac is the best still like B I N. This guide may also help.
harmonpa is offline
Old 02-01-2018, 08:20 PM   #13
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,160
Harmonpa, I think the OP has got this job done by now, infact he is probably ready to paint it again.
Ohio painter is offline
building a shower bench when using backer board on walls? wopachop Tiling 70 04-08-2010 09:19 PM
Funny Craigslist ad for paint work... Splinter Painting & Finish Work 14 06-10-2009 06:43 AM
improving adhesion of mud on painted walls d's Drywall 18 04-22-2009 08:38 AM
Smooth Finish Heavy Textured Walls riccog Drywall 5 03-10-2009 11:57 AM
Painting/waterproofing basement walls...?? RandyB1986 Painting & Finish Work 2 02-18-2009 06:29 AM
