Old 05-04-2008, 03:54 PM   #1
Trade: Finish Carpentry
Best Primer & Paint for porch railings ?
Hi Guys: I need to repaint some white exterior porch railings. The substrate is definitely pressure treated, and I think pine(?) that was painted about 4-5 years ago with Behr DeckPlus Solid Color (white) Deck, Fence & Siding woodstain (100% Acrylic latex). This is the only coating that has been applied. It is now peeling in spots. I think it would be very difficult to completely strip, so I'm thinking I will wash, scrape/sand and then apply new primer and paint (white), preferring to use the best possible combination of the two. This is in SW Missouri, i.e. relatively high humidity and the railings are exposed to sun mostly all day. What primer/paint brands would you recommend? Oil or latex primer? I really appreciate your comments.
gtmeade is offline   Reply With Quote
Old 05-06-2008, 01:16 PM   #2
Trade: painting
Exposed horizontal wood surfaces won't hold paint for long.
I'd use an oil base exterior wood primer, and acrylic latex...might last 2 years.
Steve Richards is offline   Reply With Quote
Old 05-17-2008, 06:43 PM   #3
SANDBLASTING & REMODELING
plazaman's Avatar
Trade: SODA BLASTING & REMODELING
curious, reason why?
www.perfectocorp.com
plazaman is offline   Reply With Quote
Old 05-17-2008, 11:20 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
I'm shocked the Behr solid stain took 4-5 years to peel
...really
But anyway...no paint
More solid stain
You'll have to get rid of any/all of that Behr crap though
Anything that's not really firmly adhered
Signature Quote
slickshift is offline   Reply With Quote
Old 05-18-2008, 08:54 AM   #5
Trade: painting
Old base primer soaks in, drys waterproof. Acrylic flexes with the wood during changes in temperatures.
*lighting my pipe, and putting my feet up*
I had a problem handrail once. It was all the way around a massive deck. It had been painted w/oil base gloss, and by the time the guy called me it was shot, peeling and rotting everywhere.
Stripping would have cost more than replacing. I told him that nothing I could put on it would last. It wasn't that he didn't believe me, but he ask me to do what I could. I told him it'd have to be T&M, and that we'd do some experimenting.
So I replaced a few of the (2x4 douglas fir) sections on the sunny side.
One I primed w/oil, painted latex acrylic.
Another I primed latex, painted latex.
And on one I stained w/solid color oil stain. (I'm pretty sure it was Olympic, but it was a long time ago).
The next Summer all had peeled (the oil stain more "flaked" than peeled), but oilprime/acrylic held up best.
So every year I'd go back up (he lived in the mountains) do some sanding, priming and painting-as needed on the old painted areas, to keep that handrailing looking nice until the next year. I know what some of you are thinking...but it kept him happy. And besides...they weren't MY handrails.
Over the years I also tried many different wood fillers, hardeners, and caulking up there, but that's another story..
BTW..the deck floor I stripped and put a semi transparent oil stain on, and it lasted longer than the homeowner. But he was in his 80's when I first met him.
And that's why I said: "Exposed horizontal wood surfaces won't hold paint for long.
I'd use an oil base exterior wood primer, and acrylic latex...might last 2 years."
But I'd also add: unless you can start over and use a semi transparent oil stain.
Old 05-18-2008, 08:15 PM   #6
Trade: Painting & Remodeling
We offer a pretty solid warranty on all our work, however I will not and do not offer a warranty on porch/deck floors and handrails. Solid color stain is what I have seen last the longets but the floor will need touch up every year.
BMAN is offline   Reply With Quote
Old 05-22-2008, 08:36 AM   #7
Recommendation from SWilliams
Thanks to all of you for your comments. To clarify one thing, the Behr stain did begin to peel after about two years on the top handrails (horizontal) but all the other surfaces were ok. At that point, the owner slapped a single coat of Glidden Gripper latex primer just on the top surface of the handrails which lasted another 18 mos or so. I have now power washed and the stain on all surfaces just came flying off, i.e. it was all just loosely stuck on. At least 60% of all the original stuff came off. I then sanded and lightly powerwashed again to remove all the flakes/dust. I then talked to my local SWilliams dealer and the SWilliams online help and they both said the same thing. They recommended prime with A-100 oil and cover with one or two coats of their "All Surface Enamel". I think I will try that and see how long it lasts. Thanks again.
Old 05-22-2008, 09:23 AM   #8
Trade: painting
Sounds good to me, gtmeade.
An enamel wouldn't be my first choice, but I sure don't know everything..
(I don't tell my kids that though)
I hope you'll come back in a year or two and let us know how it holds up.
The keys to a successful paint job:
1. Don't get hurt
2. Get paid
3. Make the customer happy enough that he'll call you again next time.
Good luck
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 01:05 PM
Tinting primer question icfbunt Painting & Finish Work 5 12-12-2006 06:44 PM
paint coming off the ceiling lornmastro Painting & Finish Work 6 06-02-2006 12:31 PM
