Best Primer For Bare Pine And/or Raw Drywall?
What is the best primer to use on raw pine and raw drywall?...If it is oil based, is there a good water based alternative? I want to use an airless and would rather not spray oil if I can avoid it. If I can't it's not the end of the world. I searched and surprisingly got no matches to my thread title.
#2 | |
...jammin
Trade: Rock Disciple
Re: Best Primer For Bare Pine And/or Raw Drywall?
It depends
If the pine is knotty, yeah you'll need oil for that If it's clear, then latex would be OK Personally I like Pittsburgh's Speed Hide Primer/Sealer for new drywall Ben Moore's Fresh Start for pine (oil or latex depending)
Signature Quote Quote:
Thanks Slick. I,ve been told I should use a seperate hose for my airless for oil based products. Do you agree with this, or do I just need to flush mine out properly?
Somebody here mentioned putting a waterproof glue like Titebond II on knots to prevent bleed through. I haven't had a chance to try it yet but it sounds like a solid idea. Lately I've switched to BM's Fresh Start Penetrating Primer, it's a sure cure for cedar bleed.
Cabinetmaker
I have been told that good ole shellac over the knots,ect seals em for good
I love this site....It makes everyone better at their job...Thanks everyone.
still could use advice about the airless hose. Oil and water through same hose...or buy a seperate one? |
painterofeverything
same hose,just flush it well ,very well (this is not lacquer so its not going to loosen all the crap in your line.
#8 | |
Professional Painter
Trade: Owner/Operator
Re: Best Primer For Bare Pine And/or Raw Drywall?Quote:
As far as the primer: Oil based if it is a wood that bleeds, typcially harder woods-SW Problock Oil based (they make an odorless as well...it still smells a bit) Latex for pine - I use SW preprite problock Zinsser BIN for knots-2 to 3 coats
Rich |
#9 | |
My custom title
Bah... I don't really like swapping back and forth my machines from oil to water just due to the expense of cleaning them, however... haven't had a problem doing so in 30+ years.
Agree with the really knotty oil, flat sheetrock? I prime with the cheapest there is then sand all the hairs.. go from there.... if it's textured I sorta like BM's undercoat.
Benn Quote:
| best drywall primer | Miniroller | Drywall | 25 | 10-31-2011 04:14 PM |
| Drywall primer peeling problem?? | DeanV | Painting & Finish Work | 23 | 02-02-2008 11:02 AM |
| High build primer for Drywall new | plazaman | Painting & Finish Work | 9 | 08-12-2007 07:59 PM |
| AskTheBuilder.com - Video - Drywall Primer | LennyV-NHSNOLA | Painting & Finish Work | 0 | 03-06-2007 01:30 PM |
| primer only on new drywall ceiling | georgia dawg | Painting & Finish Work | 18 | 01-26-2007 10:25 AM |
