Trade: Misc. Residential
Best Method For Painting Beadboard
I'm installing beadboard on most of the walls of a bathroom remodel. These are pre-primed 4X8 sheets. I want a semi-gloss finish (white). In the past I have always brushed my trim with quality paint (Kelly-Moore) and brushes. This however, will be way too much surface to brush. I do not have access to a spray set-up. I see these little foam rollers used on the home improvement shows and have always poo-ed them off, but am wondering if this would be a good alternative. Again, this will be on the walls, and I'm using Kelly-Moore latex. Flotrol sounds like a must too.
Any product and technique suggestions would be appreciated. |
Back from the dead...
Trade: Paperhanger/Painter
Re: Best Method For Painting Beadboard
How about using a 9" roller with 3/8" nap and tip it off as you go?
I agree, roll it on with a sausage roller then straighten it all out by backbrushing it to have all of your brushstrokes going the same way. Rolling it will avoid it dying on you too fast and ending up with crappy looking brushmarks.
If it's real beadboard you'll need to brush down into the beads then roll. Rollers wont get down in there unless you use a 1/2"+ nap and then tip out the whole job.
Trade: Squirrel Handler
Spray them before installation (in a controlled environment) and then touch up whatever needs touching up after install.
Never mind, I read to fast, I thought you said you have access to a sprayer set up, you might consider renting one if the job is big enough. .
Some people climb mountains. I take out the trash. But we both do it for the same reason. Last edited by mickeyco; 09-16-2008 at 11:50 PM. |
So, if I'm hearing you guys right, brush in the grooves (remember these are 4X8 sheets of pre-primed MDF type material) then roll it with a 3/8 roller (wool or syn??) and then backbrush it when it's still wet? No flotrol? No foam brushes ?? What do you mean by sausage roller?
...brush the grooves, roll it out, then backbrush - right? |
| Wall build method help | Captainsls | Masonry | 14 | 05-14-2008 07:33 PM |
| Best method to replace a window with vinyl siding | importer | Carpentry | 3 | 04-11-2008 09:10 PM |
| Best Hanging Method | Torn-Again | Drywall | 8 | 02-14-2008 09:11 PM |
| Azek beadboard | RobertCDF | Carpentry | 4 | 09-23-2007 11:56 PM |
| Your prefered method of cabinet installation. | Mike Finley | Kitchens & Baths | 13 | 04-27-2007 06:18 PM |
