Best Exterior Latex Primer?
Old 11-02-2006, 02:09 PM   #1
toddcla2002's Avatar
Trade: Paint Contractor
Send a message via AIM to toddcla2002
I am looking for the best exterior latex primer that will keep cedar tannins from bleeding through. I have been using SW A100 oil and am not fond of the smell, cleaning, and then handling the paint thinner at the end of each summer in regards to disposal. It's a lot of extra work by the time I've accumulated gallons and gallons! What would you recommend for an extraordinarily solid exterior latex primer? Peel bond? THANKS!
~todd
toddcla2002 is offline
Old 11-02-2006, 02:18 PM   #2
DeanV's Avatar
Trade: Painter
Re: Best Exterior Latex Primer?
I do not think such a product exists yet, there are some that are supposed to be pretty good, but they still are not close to oil's ability to lock in tannin.
DeanV is offline
Old 11-02-2006, 05:01 PM   #3
Professional Painter
Richard's Avatar
Trade: Owner/Operator
~todd
hmmm...there's nothing better, in my opinion, than oil primer for tannin and sealing. There are latex products that are decent, but not nearly as good.
But...the best latex primers IMO for tannin and such are SW's "preprite"(problock) and BM's "fresh start" acrylic
Good luck
Rich
Richard is offline
Old 11-02-2006, 05:39 PM   #4
KellyPainting's Avatar
Trade: Painting Contractor
I always prefer oil primers.
KellyPainting is offline
Old 11-02-2006, 06:00 PM   #5
Pro Painter
AAPaint's Avatar
Latex primers aren't going to hold tannins back with any kind of certainty. The problem is latex is water...water soaks into wood, frees up the tannins, and they then become part of your paint before it dries. I always use an oil base in those situations, or go for the BIN.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 11-02-2006, 06:14 PM   #6
My custom title
Brushslingers's Avatar
Alchohol based. Isn't oil, isn't latex, but will seal your tannins.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 11-02-2006, 06:46 PM   #7
Miniroller's Avatar
Trade: Painter
BIN 1-2-3 says it blocks tannin bleed if you let it cure for 24 hours. I used 1-2-3 on some cedar plank well over a month ago and painted it 2 coats acrylic on top. I haven't seen any bleed yet and it's been fairly rainy. I've also used two coats of X-I-M UMA primer on cedar and that has worked too. Still, it seems good oil primer or Cabot problem-solver is the best in my opinion.
Miniroller is offline
Old 11-02-2006, 07:44 PM   #8
Woz the Painter's Avatar
I would not go to crazy using an alcohol based primer on exterior work because it does'nt hold up to moisture very well...
Woz the Painter is offline
Old 11-02-2006, 07:59 PM   #9
DeanV's Avatar
Trade: Painter
Definetly agree with Woz on that one. Shellac acts as a vapor barrier so moisture moving through the siding from the inside will not be able to escape= bad news. It is okay for spot priming knots, but that is about all I would use it for outside. I would think it would be too brittle as well. I cringe when I see shellac mentioned as an exterior primer
DeanV is offline
Old 11-02-2006, 08:23 PM   #10
Pro Painter
AAPaint's Avatar
Amen....guess I could have stated it better. The first thing I go for is an oil/alkyd primer on just about any exterior surface. The BIN is for the tough stuff oil can't hold back like the knots you mentioned. I agree it's a bad idea as on overall exterior primer. Why would we all be using acylics if we wanted something brittle that doesn't breathe?
Anyway....latex isn't going to cut it on wood tannins any better than it would a water stain, lol!
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 11-02-2006, 09:13 PM   #11
My custom title
Ehh, what on earth do you guys think oil primers do? Let moisture escape? In the 20's they used kerosine to prime... see any 20s era houses with much rot?
Benn
Old 11-02-2006, 09:23 PM   #12
Joewho's Avatar
Trade: Painter
Wheres kellypainting? He can tell you about linseed oil primers......
*&%%$##^%% knucklebusting *&^%%##@@$&
Joewho is offline
Old 11-02-2006, 09:31 PM   #13
Richard's Avatar
"Best exterior latex primer"
Who has actually answered you?
Rich
Richard is offline
Old 11-02-2006, 09:57 PM   #14
My custom title
Linseed oil... used it for years... why would you bring that up though? It was old style formulated oil. Changed about 8 years ago. Only time I've used it lately is to treat the bare wood handrails in the local hospital... which got ran over with poly. You can't buy linseed oil primer anymore.
Anyhoo, Paintguy is right, best LATEX primer I have used is problock, SW. Prolly won't hold off the tannins in cedar with one coat but, does pretty good as a latex tintable primer.
Benn
Old 11-02-2006, 10:19 PM   #15
Mike Danahy
Danahy's Avatar
Trade: Signature Painter
I got a call from a sign maker dude 3 years ago, had a rush job that I couldn't pass up. Wanted the bare posts painted with one coat tinted oil zinser cover stain. I drive by the sign all the time, and to this day it looks like a zillion bucks. No top coat, just the one coat of primer.
Anyhow, today it's my primer of choice for everything I prime.
Danahy is offline
Old 11-03-2006, 03:50 AM   #16
rws's Avatar
Trade: paint contractor
Send a message via AIM to rws
Best is Cabot or California trouble shooter primers.But the latex is not as effective for holding back tannin as the oil is.Cabot BM and California all make linseed oil primers and all linseed oil primers breath.If I was going to use a all acrylic system on bare cedar I would use Cabot wood brightner first to remove tannin,then 0ne coat of Ca. or Cabot acrylic primer brushed and then two acrylic finish coats.
rws is offline
Old 11-03-2006, 03:28 PM   #17
Thus far I like what miniroller said....I have looked into the BIN product and may give that a test next year. I will be the first to admit that I am lazy and would like a primer that doesn't require paint thinner to clean-up. Thank you all!
~todd
Old 11-04-2006, 10:07 AM   #18
My custom title
I'll be, your right. The formulation is still the newage junk but, i'd advise anyone trying to use linseed oil paint to be very, very careful. There is a reason most states/paint companies banned it. Material sheets all say you have to pre-prime tannin/nail rust before using it though... heh. The California one looks decent, 2.1 mils dry for primer.. not bad at all.
Benn
Old 11-05-2006, 08:03 PM   #19
rws's Avatar
California and Cabot do make some nice products and are great to talk to on the phone if you have questions.They dont oversell the products and make outrageous claims like some of the bigger companys do.
rws is offline
Drywall primer peeling problem?? DeanV Painting & Finish Work 23 02-02-2008 11:02 AM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 01:05 PM
Tinting primer question icfbunt Painting & Finish Work 5 12-12-2006 06:44 PM
Primer needed on metal garage door??? Zeebo Painting & Finish Work 11 08-19-2006 05:35 PM
alkyd primer or not cowtown Wallpaper 8 08-11-2006 12:46 AM
