Best Drywall Sealer - Bath
Old 07-25-2017, 06:26 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,418
Have a combination of greenboard/regular board.
Looking for the best sealer (within reason) to keep moisture from entering.
artinall is offline
Old 07-25-2017, 06:29 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,977
Re: Best Drywall Sealer - Bath
1-2-3 will be fine.
MarkJames is offline
artinall (07-25-2017)
Old 07-25-2017, 08:14 PM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,678
Schluter Systems KERDI!
Unless you actually meant paint. I use 1-2-3 for a base coat.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
SmallTownGuy (09-30-2017)
Old 07-25-2017, 08:26 PM   #4
MarkJames's Avatar
Hold on..in the wet area (tub/shower), or outside?
Old 07-25-2017, 08:47 PM   #5
Tom M's Avatar
Rewards Points: 6,456
I like BM Fresh Start although a bit pricey
Tom M is online now
Old 07-25-2017, 09:55 PM   #6
avenge's Avatar
Rewards Points: 2,798
BIN shellac but the top coat is more important.
avenge is online now
Old 07-25-2017, 11:32 PM   #7
VinylHanger's Avatar
Rewards Points: 7,612
Gripper, but I use it for everything.
VinylHanger is online now
Old 07-26-2017, 02:11 PM   #8
artinall's Avatar
area all interior bath areas, same product...
artinall is offline
Old 07-26-2017, 02:14 PM   #9
MarkJames's Avatar
If you're talking about inside the tub/shower area, you need two coats of liquid waterproofing. Redguard, Aquadefense or similar....or Kerdi membrane. (This is for tile?)
KitchenAndBath (08-01-2017)
Old 07-26-2017, 02:22 PM   #10
artinall's Avatar
No tile. Only want to prime/seal on raw drywall, not after the paint (higher gloss paint).
artinall is offline
Old 07-30-2017, 03:20 AM   #11
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 482
Originally Posted by avenge View Post
BIN shellac .
Great primer for problem areas, but is runny and too odorous for most priming.
Caslon is offline
Old 07-30-2017, 02:57 PM   #12
avenge's Avatar
He asked for the best primer for his problem bath. If just anyone can paint what the hell do I care they can't apply it and can't stand the odor.
Old 08-01-2017, 01:23 AM   #13
Caslon's Avatar
Rewards Points: 482
Ease of application and saving of brain cells. The best is not always necessary.
Caslon is offline
Old 08-01-2017, 06:45 PM   #14
PNW Painter's Avatar
Trade: Painter
Rewards Points: 66
If you're looking for the best drywall sealer/primer I'd recommend Gardz. Apply 2 coats to ensure you didn't miss anything, but 1 coat should work fine if you apply it as heavy as you can. Because Gardz is so thin (think water like consistency) it penetrates into the drywall and seals better than anything else I've found.
Here's a link to the product data sheet: http://www.rustoleum.com/~/media/Dig...ealer_TDS.ashx
If that's not available then I'd use 1-2-3.
PNW Painter is online now
The Following 3 Users Say Thank You to PNW Painter For This Useful Post:
artinall (09-30-2017), Gumshoe (08-01-2017), Peter_C (08-02-2017)
Old 09-29-2017, 08:35 PM   #15
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
gripper would probably work fine.
DiaperRiot is offline
Zinsser 123 for new drywall? renov8r Painting & Finish Work 11 09-10-2013 07:35 AM
Kerdi Board to Drywall Stunt Carpenter Kitchens & Baths 5 06-18-2013 12:11 AM
drywall subs needed ASAP estimating2013 Help Wanted or Looking For Work 4 04-27-2013 06:46 PM
Priming & Painting drywall Repairs, not new drywall mcgyver79 Painting & Finish Work 21 04-23-2013 03:47 PM
Drywall GettingBy General Discussion 3 06-16-2011 12:58 PM
