Best Brush For Minimizing Brush Strokes - Painting & Finish Work - Contractor Talk
Old 03-01-2018, 08:16 PM   #1
gsdnno's Avatar
Trade: trim/finishing
Rewards Points: 16
Need some advice on a really good trim brush . I use Ben Moore Advance , and need a brush that will minimize brush strokes . The trim in my house is all flat with the exception of the crown molding which is a large (4") cove mold. I have been using the brushes that Wooster recommends with poor results . I see that there is a company in South Dakota that manufactures brushes called "Zenith " that supposedly delivers a fine finish . I also may be using an incorrect style of brush on my flat trim , so I may need to be schooled there as well . I like the feel of an angled sash brush , but not the finish I'm getting
gsdnno is offline
Old 03-01-2018, 10:12 PM   #2
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,016
Re: Best Brush For Minimizing Brush Strokes
What about useing some extender like XIM ?
Steve
We Fix Houses is offline
Old 03-01-2018, 10:21 PM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,784
Advance isn't a latex paint. It already levels about as good as anything.
Golden view is offline
Old 03-01-2018, 10:27 PM   #4
tjbnwi's Avatar
Rewards Points: 4,964
Just got a Purdy Clear Cut Elite. Very happy with it.
tjbnwi is online now
Old 03-02-2018, 06:05 AM   #5
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,634
Paint faster, don't over brush it.
Home Designer Series Software
B.Johnson is offline
Old 03-02-2018, 06:53 AM   #6
BeforeChristoff's Avatar
Trade: RENOVATIONS
Rewards Points: 88
Yes I use the different Purdy brushes as well, they have different stiffness's for different viscosity of paint
BeforeChristoff is offline
Old 03-02-2018, 07:26 AM   #7
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 4,760
That’s a stiffy for cutting in. He wants a softy for a smoother finish. I like a Nylox.
Purdy Ox Hair might be good with Advance? Never tried it though.
Big Johnson is online now
Old 03-02-2018, 08:01 AM   #8
hdavis's Avatar
Rewards Points: 3,149
You should be able to get a smooth finish with a Wooster Silver Tip wall brush.
You'll get brush marks if you:
Put it on too thin
Over brush it
Work too slow
Press too hard when you tip off, it takes a light touch
Angle sash brushes are tricky for trim, they Don't hold as much paint as a wall brush and it can be tougher to get a good tip off.
hdavis is online now
Old 03-02-2018, 06:26 PM   #9
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
I like angled brushes in general, easier to get into corners. For smooth surfaces I like my Purdy China bristle for oil based paints. It's natural product and the ends are tapered, unlike nylons. Temperature will play a big role too. Too warm and the paint doesn't have time to level out. Too cold and it can sag.
RangoWA is offline
Old 03-02-2018, 08:07 PM   #10
edward trowelhands
Trade: Diplomat
Especially with Advance. I actually often follow my work with a heat gun to avoid sags. It's a slow paint. I prefer to use it at close to 80 degrees and low humidity.
Metro M & L (03-08-2018)
Old 03-02-2018, 08:09 PM   #11
tjbnwi's Avatar
Originally Posted by Big Johnson View Post
Thatís a stiffy for cutting in. He wants a softy for a smoother finish. I like a Nylox.
The brush holds enough paint to lay down a beautiful layer of paint.
I'll get some pics next week.
Old 03-03-2018, 09:49 AM   #12
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,496
No need to repeat all the good tips already given but I will add, as you say it is not latex paint, for oil finish paint I prefer the white bristle over the black China bristle brushes.
You won't go wrong with a Corona Pal brush for finishing with oil.
Ohio painter is offline
Old 03-06-2018, 04:30 AM   #13
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,432
Angular brushes rule. That is all yee need to know. I stopped using square cut brushes light years ago. Mind you, I could wield a 4" square cut brush on window trim, back in those days. I was that good with a big square ended 4" brush. "No big whup, wanna fight about it?" (Family Guy).;/
Caslon is online now
Old 03-07-2018, 06:59 PM   #14
edward trowelhands
Trade: Diplomat
BM Advance, brushed 2 coats with a Wooster pro. Pre-primed FJP trim which is harder to eliminate brush strokes because it dries to fast.
With Advance, I lay it on and then brush it out about 5 times to even it out.
best brush for minimizing brush strokes-28430312_1806197252773425_3770775561249488896_n.jpg
The Following 3 Users Say Thank You to Golden view For This Useful Post:
Rio (03-09-2018), Robie (03-10-2018), Xtrememtnbiker (03-07-2018)
Old 03-08-2018, 09:18 PM   #15
I don't disagree and use an angular brush daily, but for oil trim paint i disagree, out comes the Corona Pal every time, but to be honest i am using less and less oil. To each their own.
Old 03-09-2018, 06:01 AM   #16
B.Johnson's Avatar
Trade: Builder
Light years is a measurement of distance, not time. Unless you intended to say "I stopped using square cut brushes a billion miles ago" then you are using the term "light years" incorrectly.
Old 03-09-2018, 06:18 AM   #17
RangoWA's Avatar
Trade: General
Space is time.
RangoWA is offline
Old 03-24-2018, 04:41 PM   #18
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 4,112
Since SW bought Purdy I kinda feel out of love with them, but you gotta love a Corona brush local painters here love them, they are made in Tampa
sunkist is online now
Old 03-24-2018, 05:11 PM   #19
hdavis's Avatar
I did notice the change in Purdy. I'm on the fence with Coronas. They make good brushes. I haven't tried their newest ones, but Wooster makes some good ones I like as well or better.
One thing about Coronas, if I let someone use one and they don't get it cleaned out well, it just torques me.
BlueRidgeGreen (03-24-2018)
Brush strokes with Floetrol GODZILLANINJA Painting & Finish Work 17 08-10-2014 09:56 PM
Tips for selecting the right brush michaelsaam Painting & Finish Work 7 04-19-2011 09:52 PM
Roller Marks and Brush Marks michaelsaam Painting & Finish Work 0 02-28-2011 08:49 PM
Personal choice for poly brush platinumLLC Painting & Finish Work 5 03-09-2009 09:29 PM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 10:58 PM
