Benjamin Moore Fresh Start® All Purpose 100% Acrylic Primer
Old 08-13-2009, 06:49 PM   #1
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 8,389
I just used it on some shutters I built. Sprayed it in my spray room through a pressure pot gun. I thinned it 8% to get good atomization. Great coverage and very little grain raising. It dried pretty fast. I had 19 shutters to do and by the time I finished the last one I was able to sand the first one and it sanded to a nice dry powder. Very impressed with it. Usually I use fresh start Alkyd.
Anyone else try this? Any comments about it?
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 08-14-2009, 04:53 AM   #2
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Rewards Points: 4
Re: Benjamin Moore Fresh Start® All Purpose 100% Acrylic Primer
It is almost all I ever use unless I need a stain killer or am going over wall covering paste.
chris n is offline
Old 08-14-2009, 07:04 AM   #3
LRG WoodCrafting
Leo G's Avatar
The one I am using says it is a stain killer. It says you might have to do two coats to get rid of bad bleed through, but it does say it is a stain killer. I am using it on Spanish Cedar, so far no bleed through. Only been a few days though, and the wood wasn't releasing pitch either.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-14-2009, 12:10 PM   #4
Rewards Points: 2,000
I'd love to hear how it works
over time.
I'm afraid to try any waterborne primers
since I've had some kind of problem
with every one so far.
I like the idea of them, just been burned
too many times.
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
We Fix Houses (08-23-2009)
Old 08-14-2009, 03:21 PM   #5
LRG WoodCrafting
Leo G's Avatar
What kind of problems we talking about?
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-14-2009, 03:26 PM   #6
Bleeding, flaking, peeling.....
pretty much what you'd get
with no primer.
I'm not knocking the BM,
just not anxious to be a
crash test dummy again.
neolitic is offline
Old 08-14-2009, 03:31 PM   #7
LRG WoodCrafting
Leo G's Avatar
I didn't know I was priming your shutters
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-14-2009, 03:38 PM   #8
I'm glad to hear about new ones.
I just gave up on trying every one
of them on my own.
neolitic is offline
Old 08-14-2009, 03:41 PM   #9
Mellison's Avatar
Trade: Home Improvement General Contractor
It's all I use. Have been for years with no problems.
It's B M's best latex primer.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Old 08-14-2009, 03:49 PM   #10
LRG WoodCrafting
Leo G's Avatar
The paint that the HO picked out was Sherwin Williams Duration, I had MoorGard® 100% Acrylic Low Lustre Latex House Paint speced out in my contract but she wanted the SW color and the formula BM had didn't matche the color on the card. SO she wanted the SW to make sure the color was correct. She paid for the paint instead of me, so what am I gonna say? I know it was a quality paint, not some Baer crap . I have heard good things about Duration [here]. I went to the SW outlet to pick up 2 gallons and asked the guy about the specs, specifically for spraying. It is listed as a 7 mil thick wet coat, 2.8 mil dry. Holy crap, talk about thick. The Ben Moore is speced out at 2.8mil wet and 1.6 mil dry. The guy boasted how it covered better than the Ben Moore. Gee, I should hope so, at 250% thicker application it better.
Well, I put it in my pressure cup gun, thinned 8% and it is still so thick it won't spray with a nice atomization. You gotta remember I am a finisher, not a painter. I sprayed the backs of the 2 small shutters and let them sit for a bit. It wouldn't lay out smooth. So I through in another 8% and tried again. Played with the gun a bit and got it pretty good. I doubt I put it down at 7 mil, but it is possible. It was pretty thick. Laid out nice.
This was just the backs, and they will never be seen again. The fronts will get two coats. Tonight I'll spray the fronts with the first coat and tomorrow the second - then vacation in RI for a week. They should be plenty dry by then.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-16-2009, 09:26 PM   #11
Paulf's Avatar
Trade: Painter
I don't like the acrylic fresh start, Ive had adhesion problems with it, perhaps it was a bad batch but I can't afford to find out
Paulf is offline
Old 08-16-2009, 09:29 PM   #12
LRG WoodCrafting
Leo G's Avatar
Did you sand the primer before you top coated, or just put the paint on without sanding?
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-17-2009, 09:57 PM   #13
Store Owner
NCPaint1's Avatar
Trade: Paint Store Owner
Rewards Points: 75
If people have problems with primer...typically its self inflicted. The substrate needs to be clean, dry, chalk, and mildew free. New wood needs to be sanded...must be sanded. Not sanded with 400, just enough to break any glazing, and open the grain. 80-100 grit is usually fine.
Yeah, duration is thicker, compare spread rates too. Its roughly half what Moorgard or Aura is.
NCPaint1 is offline
Old 08-17-2009, 10:43 PM   #14
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
with no primer.
Bleeding can happen with all waterborne primers. Really depends on the substrate you are going over. Flaking and peeling are usually due to operator error. See below.
ProWallGuy is offline
Old 08-17-2009, 11:35 PM   #15
Hmmm, don't usually sand
old window muttons and sash,
I'll admit.
But the same procedures seem to
produce better results with oil.
neolitic is offline
Old 08-18-2009, 12:23 AM   #16
Paulf's Avatar
Trade: Painter
Nope... the primer went over a sanded clean surface, imo a primer should do better than that! Don't get me wrong I like BM products just not this one!
Paulf is offline
Old 08-18-2009, 04:24 AM   #17
chris n's Avatar
Rewards Points: 4
I hope that poor boy does not grow up having to wear that hard hat
He is cute though, must take about 99% from his mother.
chris n is offline
Old 08-18-2009, 08:05 AM   #18
Store Owner
NCPaint1's Avatar
Rewards Points: 75
Has to be a moisture issue. If something peels like that and was prepared properly, the only reason left is moisture.
On a side note, try Sikkens Rubbol DEK (oil) or Rubbol Solid DEK ( latex). If you have problem areas ie. window sills, this product is amazing for them. It uses microporous technology, it allows moisture to pass through the film resisting peeling. You don't prime with this product. Prep as normal, then 2 coats.
NCPaint1 is offline
Old 08-20-2009, 11:39 PM   #19
Paulf's Avatar
Trade: Painter
Nah... no moisture involved, just failed badly. Since it gets so many good reviews perhaps it was bad batch
Paulf is offline
Old 08-22-2009, 07:52 AM   #20
Store Owner
NCPaint1's Avatar
Rewards Points: 75
Were they stained before? I know when homeowners use products like Pledge on their wood, it can cause this. I've also known people to Pledge painted trim and similar surfaces....I wonder if your problem wasn't caused by this. Just food for thought.
NCPaint1 is offline
Paint or stain on hardi plank? Jer Painting & Finish Work 28 02-17-2017 07:29 PM
Fresh Start Acrylic Primer? jerome8283 Painting & Finish Work 3 02-27-2009 06:34 AM
Benjamin Moore Regal vs Muralo Beginner123 Painting & Finish Work 1 09-16-2008 10:27 PM
Benjamin Moore / Aura Paint paintprogal Painting & Finish Work 3 08-19-2008 05:30 AM
Acrylic Primer Exterior mjay Painting & Finish Work 6 10-29-2007 05:50 PM
