#21 |
Trade: Paint
Re: Behr Paint...Why Does It Suck?
I've just done some testing with a few paints. I rolled out 4 paints. All with same sheen levels. Very close to the same color. I used, Colorplace, Ace Royal, Behr Prem Plus, PM 200. Couple things I noticed was that after the paint dried and cured is the washability and burnish resistance of the coatings. While we tend to talk about coverage, drag, brush and roll characteristics (which there was big differences). I got each paint to cover in two coats. Some paints had bad drag. Behr had huge stipple to it. Colorplace actually laid down but was draggy. Ace was fair with both. 200 worked pretty good. If I was doing smooth walls, Behr would be one of the last I would use. Burnish resistance was very noticeable. It took one stroke of finger rub to burnish Colorplace badly. It took just a couple to burnish Ace. Behr burnished fairly easily too. It took extreme rubbing to burnish 200. I washed the samples with the same amount of pressure and strokes. Colorplace and Ace color rubbed off easily. Behr was actually pretty decent. I would recommend any of you to take time to test out different paints. Do a blind test if necessary to keep out any biases you may have. My point is, we talk about the application alot, but what is the end result is just as important. What is left with our customers. Not all of them look at the walls at an angle in the light. Not all wash there walls or wash them properly. Everybody has different expectations.
#22 |
President of the world
Trade: general contractor
and none of my customers want to hear I'm charge'n them more cause the dang paint didn't cover in 2 coats... oopsie daisy, my bad.
people use professionals cause we are supposed to be well informed and experianced... the info on behr is not very good and my experiance with behr is not very good i'm sure behr works great for alot of people for alot of reasons, but there are too many other paints i would use before i use behr again |
#23 |
Trade: Painting & Flooring
There is one more, small, reason behr paint sucks. Until recently, last month, Home Depot did not negotiate with contractors. I haven't talked to them yet but it's something along the line of 10% off if you spend 2k or more.
For your average painting outfit the discount that you get from being a big loyal regular customer becomes very important to the bottom line. In the past it didn't matter if you bought 20$ or 20k worth of Behr paint from Home Crackho, the price was the same. 22.95 vs. a discounted 15.00 (or less) from a Paint retailer makes a big difference if you're applying thousands of gallons a year. |
#24 |
Trade: Painting - Restoration
I like what you are trying to say and test, but it isn’t as conclusive as you might think.
This is what I was taught… and I try to pick paints accordingly.. Sometimes I cant use the paint I want b/c the consumer/individual cannot afford it OR doesn’t give a ****. There is no “perfect paint” it all depends on where you’re going to use it and what condition/material the object is in. Content of paint varies tremendously between companies… here are some of the factors. First of all (most important)… Each company uses resin in their paint, BUT – the quality and amount of the resin is different in all brands. Resin is the ingredient that keeps the pigments and additives locked together (a binding agent) it’s the mortar of the brick wall so to speak– it also contributes to the “stickiness” and sheen present. Some lay on or brush easier because they “stick” better – higher resin content. It also contributes to the sheen.. Gloss has a higher resin content than flat etc… Just remember Resin = durability&/bonding agent and your cool.. Second, the functionality of the pant (how easy/hard it is to apply, cut, roll out etc) has EVERYTHING to do with the amount of solvent within the paints. In latex solvent is water, spirits for oil.. its that simple.. Solvent is nothing more than an agent to help you get the paint from your tool to the object, nothing more or nothing less. No rocket science here.. BUT this is where companies make HUGE bucks… They rip consumers off by “watering down their product” No different than a bar tender watering down your whiskey!! No **** guys… Cheap paint = LOTS of solvents (water or spirits) Don’t confuse additives with solvents.. Each company has special additives that increase the functions of their product.… Here, quality of that additive contributes to the products purpose + durability, such as mildew resistance etc.. I won’t say anymore on that, that’s a whole different topic. But needed to be mentioned. Last but not least – Pigment… This it huge… Just as important as the resin and differs depending on the sheen you are using.. Pigment gives you your hide/cover. There is a huge gap in quality between pigments.. And this is another way for companies to exploit consumers.. You don’t open a can of paint and put it under the microscope to find out if they used high quality pigment… =) The easiest way to explain this is by comparing very very fine sand to a hand full of river rocks. Cheap paint has low quality pigments (river rocks) and the obvious opposite to that is high quality = fine sand.. Heres why its important.. The resin binds the pigments together and creates a film, ultimately creating its resolution. The finer and increased pigment present increases coverage and thickness after the solvent dries. If there is to much solvent and poor pigment, you got your self poor coverage AND poor durability for the lack of resin. Companies are not stupid, they are out to make money. Some try to offer consumers an honest and hardy product, but consumers don’t have the time or care in the world to know otherwise. Hey, some people use cheap paint b/c they simply don’t have the money. I hope that having the ability to identify properties of the paint can help you determine what is good and what is bad. In most cases, price is an obvious indication for a novice, primarily b/c a company isn’t going to put top dollar on a bucket of clay and get away with it for long.. You get what you pay for – almost Just because you use good paint doesn’t make you a painter it just helps. |
| The Following User Says Thank You to Kuba For This Useful Post: | tkle (06-06-2009) |
#25 |
I may never be a good painter, but at least now I know more than the majority. All present company excluded of course.
Dunn Edwards puts out a bit of info on the contents of their products. Rather impressive I thought. http://www.dunnedwards.com/retail/do...CB7F8A6A8E6CD8 Good paint is very similar to good mortar. We look for the same qualities. Wrong link http://www.dunnedwards.com/retail/documents/document.asp?id={8CFC04E4-46F7-49C7-B67A-6869D2EE200E}http://www.dunnedwards.com/retail/do...-6869D2EE200E} Last edited by tkle; 06-06-2009 at 09:49 AM. |
#26 | |
Dan-Liquid Art Design
Trade: Decorative Finisher
Re: Behr Paint...Why Does It Suck?Quote:
#27 | |
#28 |
Trade: Commercial painting
Paints have several components, resin, pigments, fillers and vehicle, aka solvent which could be water or spirits. Other sub components are conditioners that help improve adhesion & application. The expensive stuff are the pigments & resin. In my opinion Behr has less resin, it applies nice and levels out good but it doesn't stick or hold together well.
I usually go by the amount of hype a product has the more hype the less money can be spent on the product. I apply that rule to most everything from movies to paint. Want a good sleeper of a paint? Give Ultrahide by Glidden a try. It's also available at HD $55 for a fiver of flat, $70 for eggshell. This is one of the best values out there Tom |
#29 |
SERVICE,,,,,,,,,Can you see me standing in the yard with homeowner and a S.W. rep trying to decide a course of action after a paint failure,,,?,,,I have and it ends well,,,,NOW visualize if you can the same scenario but instead of th eS .W. rep make it the friendly paint shaker from H.D.,,,,,,,,,Can you say BBB complaint?
| The Following 2 Users Say Thank You to davy crockett For This Useful Post: | bonz (07-01-2009) |
#30 |
Zimmermann
Trade: Wood Cutter
not enough pigment
crappy binders nuff said. |
#31 |
Sponge
Beacause they can't even spell bear right, how can they formulate paint.
San Diego Kitchen Remodeling Room Additions in San Diego Bathroom Remodeling in San Diego San Diego Electrician Kitchen and bath remodeling & Room Additions. |
| The Following User Says Thank You to tyler durden For This Useful Post: | Metro M & L (06-08-2009) |
#32 |
Re: Behr Paint...Why Does It Suck? |
#33 |
bathroom guru
Behr sucks. crap in a can
Best paint I have ever used for application, covering, consistant sheen, cleanability, and touching up 2 years later when your daughter does a chin-up on the towel rack, is C2. |
#34 |
Trade: Paint, Industrial Flooring
Dont know if it is to late on the BEHR issue but one thing to consider is what testing methods and procedures are used when Consumer report comes up with there list. Consumer report does not use ASTM testing methods which is the industry standard, if you go to a MPI website and there is an interesting test they did when consumer report came out, the BEHR product failed miserably in the testing methods and is not listed on there site for any recommendations.
#35 |
Trade: Historical restorations painter/plaster
Behr paint is there for the home owner..when they find out how hard it is to paint with it they call a painter so they can come and put up real paint!! Behr paint sometimes doesnt even stick to itself putting another coat over it...what is in the formula to make up the paint is cheap..it is full of impure fillers..maybe even chalk as a filler..the vinyl or what ever that plastic type smell you have when you open the can tells me not to use it..the amount of raw titium dioxide (the meat and potatoes) of a paint just is not there!!! It rolls out weird..if you try to back roll you are actually removing the paint..it just sucks..tell you buddy the consumer reports are untrue..the sales are up..people using the paint just figure they are applying it wrong..always go with one of the paints from the top three manufactures of paint that have a proven track record..not sure what else to say..I will never let a customer direct me with what Im to use..they go to who I deal with to look at colors..it wont be home depot!!
#36 |
Like others have said the Behr doesn't cut well, doesn't flow well out of the brush, doesn't keep a wet edge, doesn't roll well and flow out... you name it it's not anywhere close to the quality of BM, SW, or any good quality paint.
The last job I was forced to use this on was T&M for a homeowner who bought their own paint for a new addition. Instead of cutting it in once or twice it had to be done three times to cover properly. When we started rolling the walls I'd get down the wall about 10 feet and look back to see some areas starting to sag, not bad enough for a homeowner to notice but enough to have to go back and re-roll it if we wanted to get paid for a quality job. Instead of putting on two coats we had to roll three to cover the tinted primer. In the end they would have been much better off to pay me a couple bucks more a gallon for Benjamin Moore than to pay the additional labor involved to make this junk look good. I guess if your time is worth nothing it doesn't matter, use the Behr and you'll soon know why it's crap. |
#37 | |
This post is filled with so many fallacies and just plain asinine logic its almost overwhelming... but since i believe people deserve to have accurate information, here goes.
My intention was not to be an ass. I've learned a lot from this board, i believe its my turn to share some knowledge. Thank you for your time. |
| The Following User Says Thank You to Duckwarrior For This Useful Post: | JeffeVerde (04-29-2010) |
#38 |
Trade: Fan of Bodger
#39 |
paper hanger,painter
#40 | |
Trade: GC/Remodeling
Walmart paint is made by SW???... Crock, is that a crock??
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
| why is latex paint peeling?? | Zeebo | Painting & Finish Work | 24 | 05-28-2009 07:59 AM |
| Paint Sprayers | BiggersJunior | Painting & Finish Work | 27 | 01-12-2009 09:49 PM |
| Best Paint for the Conditions? | realpurty2 | Painting & Finish Work | 9 | 01-16-2008 08:02 PM |
| Possible Behr paint problem | Steve Richards | Painting & Finish Work | 35 | 11-29-2007 08:56 PM |
| Dealing with flaking paint....help!!!! | Zeebo | Painting & Finish Work | 9 | 11-28-2005 11:03 PM |
