Bathroom Re-paint...sand/paint Or Primer/paint?
Old 06-09-2009, 11:45 AM   #1
oneelwayfan_com's Avatar
Trade: Painter
After a short hiatus to get my painting business up and running, I'm finally back on here to get berated some more.
I'm doing a bathroom that already has what looks like semi-gloss, or MAYBE a slightly less dull sheen on the walls.
She wants me to paint about the same sheen on the walls, but change the color from what looks like a bright yellow, to '4002-9c Purple Whisper' from Valspar.
My question is: Would it be best to lightly sand, dust, then paint one coat of the purple, or just prime and paint.
There isn't any prep work that needs to be done, apparently the previous owners took care of their house, unlike some places I've seen in a few jobs.
I was going to just paint it, but I remembered someone on here saying something like sheen over sheen won't stick, or somthing along those lines.
Any kind-hearted people out there willing to give advice on this particular job, besides of course the snide remarks?
Originally Posted by tcleve4911 View Post
" Nothing is expensive if it pays for itself "
http://www.oneelwayfan.com for my Elway collection
oneelwayfan_com is offline
Old 06-09-2009, 12:50 PM   #2
davy crockett's Avatar
Re: Bathroom Re-paint...sand/paint Or Primer/paint?
The new acrylic paints that are sold today stick real well, how else would we ever be able to multi-coat anything.With that said we lightly sand everything even between coats for burs etc. and we use a pole sander with worn 100 grit or a lg sponge sander. so its,,,sand lightly, wipe down paint, repeat until coverage and sheen are achieved.Are you a pro painter?Training?
P.S. check out the DIY forum,,,lotto goodies on there too.
davy crockett is offline
Old 06-09-2009, 12:59 PM   #3
Trade: Painter
Thanks for the quick reply. According to most of the people on here, I'm not a 'professional', since I haven't been doing it for 20 years, but I started my business in April, and am learning as I go.
So primering it, then painting it wouldn't work, or is sanding/painting the way you prefer to do it? I'll do it either way, I just want to know the best way, as I've heard either way works.
Thanks again for your reply. I hope to get more. And if someone doesn't feel like replying, just PM me.
Old 06-09-2009, 03:08 PM   #4
Primers serve a purpose, depending on the need.When going from acrylic semi-gloss to acrilyc satin scuff sanding is 'nough. I actually scuff before I prime, as it is just a natural step.To scuff sand an average bath=15 minutes,1 pole sander,1piece for hand. To prime2hrs and $20 primer WHEW!. Now if there are issues then primer has a role. You need to get tight with your S.W. reps and store persons, and BTW most of us "pros" learned the same way you are. You are going about this the right way as the forum is rich with info, now just don't ask how much$$$$$
Old 06-09-2009, 04:11 PM   #5
Trade: Painter
Ok, so just get some what, 120 grit sandpaper? Then just lightly sand the whole bathroom, wipe off with a dry rag, then paint?
Because yeah, if it's that simple to sand the glossy paint, and just put new glossy paint on a lightly sanded surface, I can knock my bid down a little bit since I won't have to buy primer or have to charge for the labor to put the primer on.
Old 06-09-2009, 06:41 PM   #6
Steve Richards's Avatar
Trade: hack painting
No.
You're not a 'professional', because you don't know how to paint.
Steve Richards is offline
Old 06-09-2009, 09:21 PM   #7
davitk's Avatar
Trade: Perfessional Contracter
"There isn't any prep work to be done"
Guess you said it all right there. Just mask around the switch plates and let 'er rip.
Go to home Barnes and Noble and buy as many painting books as you can find, read them then turn pro.
Sorry, guess I had a rough day
davitk is offline
Old 06-10-2009, 01:13 AM   #8
Metro M & L's Avatar
Trade: Painting & Flooring
Purples can be tricky, remember there is a red component in there. Often they require grey scale primers. The folks at Blowes probably won't know what that is. You should primer and my guess is your purple will be truer to the chip if you add some black to the primer.
Metro M & L is offline
Old 06-10-2009, 01:16 AM   #9
also,
when I used valspar last, the first time was the last time, I found it to have a long cure time that was easily exacerbated by normal humidity conditions. When the customer complains that they can scrape the paint off the wall with their finger nail tell them the ambient humidity in the bathroom is slowing the already slow curing process of their box store paint.
Old 06-10-2009, 08:57 AM   #10
Then you can also tell the customer that you don't know what you're doing, and apologize for misrepresenting yourself as a painter.
Why don't you just call yourself a mechanic, open an auto repair shop, and then go on the internet and ask real mechanics how to fix whatever comes in the door?
Old 06-10-2009, 11:42 PM   #11
the hague's Avatar
If you get your primer tinted to a lighter color of what you are painting (especially if its a dark color), you will be a happy painter. Purple over yellow will require at least two coats anyhow.
the hague is offline
Old 06-11-2009, 06:32 AM   #12
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
from Valspar.
As been posted, a real painter would not use this crap. That being said, sand,lightly, and paint.
chris n is offline
Old 06-11-2009, 06:05 PM   #13
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
sand lightly
patch
paint
-don't knock your bid down either.
an average bathroom should only take a few hours anyway.
also, get yourself an account at a Sherwin Williams. They can color match to Valspar, Behr, etc...
vandyandsons is offline
bathroom ceiling paint stainlessguy58 Painting & Finish Work 16 12-17-2011 08:56 AM
paint over solid stain Ogre Painting & Finish Work 15 09-27-2011 05:12 AM
Paint or stick with solid color stain? JL1 Painting & Finish Work 41 07-28-2009 08:44 AM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
Best Paint for the Conditions? realpurty2 Painting & Finish Work 9 01-16-2008 08:02 PM
