Trade: custom metal work
Bathroom Ceiling Paint
3 weeks ago i painted my bath ceil beacuse it was starting to show old steel drywall screws bleeding rust & slight peeling .the old paint is now 15 yrs old ..so i mudded any old imperfections waited 24 hrs then primed with a *Bin primer/sealer* waited 24 hrs And through a local paint company "colour your world " took their advice and used a latex C.I.L. paint................now three wks later its peeling all-over many hrs wasted!! need advice!!! because my idea was to just cover in in stainless steel sheets but my wife says NOWAY ...in away i see her point because our house in built in 1948 all though we rebuilt most of it after a fire 15 yrs ago
So i could use some pro help on either the proper paint or any other type of suitable ceiling construction material ,,i also do have a adequate ceil exhaust fan.................THANKS! |
Trade: Painting Contractor
Re: Bathroom Ceiling Paint
Sand all the failing paint, skim coat the problem areas then prime the ceiling with oil primer. Then topcoat.
Sean |
Trade: Historical restorations painter/plaster
Yes I agree..sand and remove all fail spots/skim coat with sheetrock 90..light sand to feather it out and use oil to seal it..whether you use Kilz/flat oil or oil primer..use oil then paint it regular..you may want to go up in attic and check insulation to make sure you dont have a moisture problem there also..if you dont have a ceiling vent fan in bathroom the moisture from within is causing problem..open window after showers!!
Sorry..I see that you have a fan!!
My advice is dont go back to Color your world..try a good Para paint dealer !! A good body paint with high solids is best for any painting job.
Trade: Painting, flooring
no showers the morning before or after you paint!
Coming out of the closet
Trade: Closet Design-Install-Remodel
The surface needs to be "sound" and have "tooth" to hold the new coating. All peeling paint must be removed and the "final surface" sanded to get the best adhesion of the new paint. Then use a mildew/mold inhibitor type additive to your final coat of a high dollar semi gloss.
Trade: master painter/finish carpenter/drywall finisher
first scrape, then prime with quality oil based primer and backroll to ensure good coverage. then patch or skimcoat. sand and prime allow good dry time and paint. the reason for the primer before the patching is to prevent moisture from the mud from leeching under the old paint and causing bubbles and peeling. also finish paint should be a quality semi gloss latex.
| The Following User Says Thank You to C.J.H. For This Useful Post: | masterdawg (12-16-2011) |
Trade: I am user
I agree that firstly scrape the area thoroughly. Prime it with high quality primer and then paint. Avoid using water in that particular area till paint dries otherwise paint will wreck out.
Trade: Painting contractor
Scrape, sand, skim coat and re-prime the ceiling with a fast-dry oil based primer then you can continue painting the ceiling. Also make sure the room has a good fan that can handle the amount of humidity in the room.
#11 | |
Super Master Painter
Re: Bathroom Ceiling PaintQuote:
ill be back down in the basement after my vacation is over Last edited by Ole34; 01-30-2011 at 02:57 AM. |
Its all ball bearings
Trade: Tile
That's so feng shui.
Of course, if you're not alone that may not apply.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
#13 | |
Drywall & Painting Pro
Trade: Hang, Finish, Texture, Paint, and Repair.
EthanJoshua-Paul
-Paul PeckDrywallandPainting.com Twitter Facebook Youtube Google+ Melbourne, Fl Painting Contractor | Melbourne, Fl Drywall Contractor |
#14 | |
General Contractor
Benjamin Moore Aura Eggshell paint is durable, mildew resistant and perfect for the wet area...
Painting & Remodeling
Wilmington Bathroom Remodel | Wilmington Painting Contractor | FaceBook | JHC Blog |
Small Business Owner
Trade: Residential Repaints
use premix... green top.
then sand, then prime with either Kilz OIL or go to sherwin williams, and get Problock HS... Then, paint with semigloss, latex, either Glidden ultra hide 250, or Ben Moore Satin Impervo, or Sherwin Williams EXTERIOR Duration. Should hold up.... |
| Bathroom Paint Problem - Strange Peeling | firemike | Painting & Finish Work | 23 | 09-27-2007 07:53 PM |
| Old plaster that won't hold paint | hbiss | Painting & Finish Work | 14 | 07-28-2007 08:50 AM |
| Wait to paint ceiling texture: How long?? | steve-in-kville | Painting & Finish Work | 7 | 06-15-2007 08:39 PM |
| Paint for ceiling | lunaassoc | Painting & Finish Work | 9 | 06-27-2006 07:17 PM |
