Coating Specialist
Trade: Wood Finishing & Restoration
Bath Tubs
I've done a few bath tubs in my day of spraying wonders. Always used Tile Doc, and they seem to come out fine. Are there any other products out there that will out preform Tile Doc in the bath tub, sink, and tile refinishing department? Also in the cure and use time....
I'm looking for something that may have more body and build to it. Also, I love the new ICI Advanced Waterborne. It lays out beautifully when spayed. Brushing, like all waterbornes require a slow down agent. |
Trade: Pain
Re: Bath Tubs
I have repaired and refinished many hundreds of tubs sinks showers and counter tops on porcelian tile fiberglass cultered marble and formica.used many different brands and types of coatings for bathtubs but never any off the store shelf junk,takes to long to put back in service and epoxies will yellow in time.midwest chemicals has a very easy to use system 1-1 acrylic aliphatic polyurethane dries quick,use tub next day.I spray using a hvlp turbine system,all my refinishing jobs come out awesome.
so easy to use a cave man can do it.
Trade: painting and pressure cleaning
Re: Bath Tubs
i have done 2 tubs a sink and some tile and a kitchen sink with some stuff called tough as tile . its a pita.
pro picnic table builder
Trade: gc
Re: Bath Tubs
i want to do my own claw foot tub. I've already did the out side like you would do a car. bondo, self etching primer. lacquer white. I have lots of experiance in automotive painting. where can I buy a good product for this job. should i use one of my airbrushes or a devibliss door jam gun?
Trade: Pain
Re: Bath Tubs
dude your not listening,midwest chemicals they have a web page with everything you need to know.tell them you are getting into the business of tub refinishing and they will give you a free sample.enough to do a couple of tubs.there are other companies that will also give you free samples too,but I like the 1-1 mix
so easy to use a cave man can do it.use your gun with the larger cup takes less than 24 oz for for inside a clawfoot tub.air brush can be used but use the other.
Coating Specialist
Re: Bath Tubs
I'll check out Midwest Chemicals. Looks like they have other interesting stuff.
Thanks |
Trade: painting
Re: Bath Tubs
would an airless with a fine finish tip work?
Trade: Pain
Re: Bath Tubs
airless will work but i would not use it unless you have a big project and need to spray gallons on walls.for tubs with tile walls the most paint you will use is 32-42 oz.to much hassel and waste of material to use airless even if you just use 2-3 5' whips for paint line.you can pick up a cheap hvlp turbine for 100.00 bucks and get as good a finish as a 1000.00 system.
so easy to do a cave man can do it.
Trade: painter
Re: Bath Tubs
Do you use their primer first or just the coating itself. I have a devilbiss with a 1.5 tip. Will this spray it good enough?
Trade: Pain
Re: Bath Tubs
It depends on the substrate and condition it is in.I clean 100% entire area to be coated. all soap scum and silocone/caulking must be removed,if the tile or porcelain is in good condition i will use a wipe on primer only and 2-3 coats of top coat.if the substrate is in bad condition i will prime with epoxy and 10-15 minutes later top coat 2-3 coats.i do not prime formica cultered marble or fiberglass surfaces,clean scuff/sand and 2-3 coats top coat.
1.5 should work fine just add a little mek to thin it out a little.i use 2.0. Last edited by ibsocal; 03-19-2007 at 11:17 PM. |
#11 | |
Trade: gc
Re: Bath TubsQuote:
| Bath Fitter & 1 800 Bathtub | cabela | Flooring | 2 | 12-05-2007 09:59 AM |
| Bath & Kitchen Remodeler wanted for Upstate SC | SCDreamMaker | Help Wanted or Looking For Work | 0 | 05-23-2007 10:50 AM |
| Master Bath tub/shower | sbeaty | Plumbing | 7 | 04-24-2007 10:02 PM |
| Bath Fitter - | dirt diggler | Remodeling | 5 | 02-03-2007 11:45 AM |
| Bath Tub Paint? Supplier? | johnjamesalaska | Painting & Finish Work | 1 | 07-29-2006 09:45 AM |
