Basement Floor Paint
Old 02-25-2007, 08:53 PM   #1
When It Rains, It Pours..
highlife77's Avatar
Trade: Remodeling(Everything)
I'm looking to paint a basement floor ...I'm looking for something very durable...this is a very hi-traffic area and I need this stuff to stick and stay...any ideas???thanks.
"When It Rains, It Pours"....
highlife77 is offline
Old 02-25-2007, 09:37 PM   #2
farrellpainting's Avatar
Trade: exterior painting contractor
Re: Basement Floor Paint
you want a high build epoxy.1or2 part high build epoxies are the strongest but difficult to work with especially 2 part mixes. you can also use an acrylic epoxy re-inforced floor paint that works just like house paint not as durable though.make sure the floor is clean enough to eat off of, then etch it with muratic acid before painting,this lowers the crete's ph close to 7(neutral) to provide a good base for proper adhesion.
farrellpainting is offline
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
Wooden Basement? LWF Construction 21 05-08-2006 04:17 PM
Landscape solution to basement moisture problem RJC Construction 3 11-21-2005 01:34 AM
