Bar Top, Wood Has Shrunk. Help
Old 07-14-2008, 10:16 AM   #1
birdog's Avatar
Trade: Painting Contractor
Last fall a contractor I work for had a nice project, full finish basement with lots of wood. This included a bar built out of fir, the carpenters used biscuits and glue for the bar top, then I stained and applied 6 coats of polyuerathane. A new HVAC system was installed during the winter the HO turned the humidifier to the wrong setting basically off and all of the wood in the basement shrank, the main worry is that the bar top has large gaps between the boards 1/16-1/8" . This was my first bar top. I need some help with the best solution I can do for this project. All wood was in the basement for a couple of weeks. Do you think I can fill the cracks, stain and apply poly.
Thank you for help on this ordeal.
birdog is offline
Old 07-14-2008, 11:02 AM   #2
genecarp's Avatar
Re: Bar Top, Wood Has Shrunk. Help
of coarse you can, but you will always see your repair work, i would probably looking to veneer over the existing top if it where my job,
genecarp is offline
Old 07-14-2008, 09:59 PM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
Yes you can
-Chances are much greater that it will look like crap than that it will look good
But you can
I'd suggest a new top, a veneer, or a solid coating (to hide repairs)
Signature Quote
slickshift is offline
New kind of Pressure Treated wood karma_carpentry Carpentry 23 08-21-2008 09:06 AM
Wood choice Cdat Flooring 7 04-11-2008 08:07 AM
foamboard over wood siding-tyvek too? 72chevy4x4 Windows, Siding and Doors 6 09-17-2007 11:15 PM
Pressure Treated Wood rjordan392 Carpentry 4 05-28-2007 02:23 PM
Wood people I need your help Floorwizard Flooring 11 05-18-2006 09:07 AM
