Australian Timber Oil
Old 05-12-2012, 10:07 PM   #1
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Any one used this on Pine? Doug Fir. The girlfriend and I are building some garden workbench for her mother...I have a qt can of this stuff and want to use it. The Doug Fir is NOT pressure treated...
TBFGhost is offline
Old 05-12-2012, 10:21 PM   #2
Box Builder
Morning Wood's Avatar
Rewards Points: 8,788
Re: Australian Timber Oil
I've used it quite a bit. A lot of the suppliers seem to be phasing it out. They say people have trouble with it drying. I've never had that problem I just resided a place and all the trim and corner boards were Solid tight knot western red cedar rough side out. I used this stuff. Application is easy whIch is why I use it. It doesn't hold up,to,the elements very well though. Second coat not necessary right away but maybe 9-12 months later. I've only used natural color. Brush on, or roll on with foam roller, and wipe off with rag. I've used it on fir too, but haven't been back to see how it holds up. I wouldn't use it on a deck.
Morning Wood is online now
The Following User Says Thank You to Morning Wood For This Useful Post:
TBFGhost (05-12-2012)
Old 05-12-2012, 10:24 PM   #3
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Does your girl not know the rules of the workshop? "No women are allowed in workshop unless wearing heels and short skirts"
Retake the pic when she obeys the rules and repost
www.bcconstructionllc.com
BCConstruction is offline
Old 05-12-2012, 10:26 PM   #4
Finish Carpenter
TBFGhost's Avatar
I am plenty content with yoga pants.
Thanks, I read a review or two where people complained that it was meant for hardwoods and when used on a soft wood it came out SUPER dark, but that was on Amazon and who knows who wrote that. I think I have the Amberwood color and I am pretty sure its the Low VOC water based kind.
http://cabotstain.com/products/produ...imber-Oil.html
TBFGhost is offline
Old 05-12-2012, 10:48 PM   #5
VinylHanger's Avatar
Rewards Points: 7,254
That's not what I expected you to look like.
VinylHanger is offline
Old 05-13-2012, 06:58 AM   #6
painterman's Avatar
Trade: Historic Restorations
Rewards Points: 288
I really like the safety boots
painterman is offline
Old 05-13-2012, 03:18 PM   #7
Finish Carpenter
TBFGhost's Avatar
Honey Teak was the color....
TBFGhost is offline
Old 05-13-2012, 08:47 PM   #8
Finish Carpenter
TBFGhost's Avatar
Didn't quite get it done, but close.
TBFGhost is offline
Old 05-14-2012, 06:53 PM   #9
CaptRandy's Avatar
Trade: Deck restorations
Rewards Points: 25
ATO does not hold up more than a year then it has to be stripped and neutralized to recoat.
CaptRandy is offline
Old 05-14-2012, 07:10 PM   #10
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
.......what are ya building?
Tom Struble is offline
Old 05-14-2012, 08:54 PM   #11
Crystal Ball Malfunction
jps614's Avatar
Trade: Construction / Remodel / Home Improvement
Rewards Points: 150
a fan base for his girlfriend...
jps614 is offline
The Following 3 Users Say Thank You to jps614 For This Useful Post:
Cole82 (05-14-2012), slowsol (05-14-2012), Tom Struble (05-15-2012)
Old 05-14-2012, 09:39 PM   #12
Pelican's Avatar
Trade: Painting/Wood finishing
Rewards Points: 81
Australian timber oil is often applied by people who don't read the part about "wiping off" and that is why they have trouble with it drying. It usually holds up pretty well but does require maintainance coating though I usually just clean it and lightly sand and reapply.
I don't make the rules, I just think them up and write them down.
Pelican is offline
Old 05-15-2012, 03:53 PM   #13
Finish Carpenter
TBFGhost's Avatar
I read that you should wipe it off, but that was for the oil based version....the Water based, which is what I had, made no mention of that.
From Cabot's instruction on the water based:
Do not overapply. Shake and stir thoroughly before and during use. If project requires more than one container, blend all containers together
to ensure uniformity. Apply with nylon or polyester brushes or professional spray equipment. When spraying, always back-brush
immediately. Optimal results are achieved by using a lambswool applicator. Apply to small sections at a time (two to three boards) to avoid
lap marks. Apply one coat only. Clean brushes and equipment with soap and water.
From the oil based:
Apply Cabot
Australian Timber Oil for Decks, Siding, Railings &
Outdoor Furniture to small sections at a time 2-
3 boards at a time. Product that does not
penetrate must be removed or rubbed into the
boards parallel to the wood grain. For outdoor
furniture: Best results can be achieved by hand
rubbing the finish into the wood grain by using a
soft cloth or lambswool applicator.
TBFGhost is offline
Old 05-15-2012, 10:25 PM   #14
Pelican's Avatar
Rewards Points: 81
I've never seen the water base. If it doesn't say to wipe off then it should be all good
Pelican is offline
Old 05-15-2012, 10:55 PM   #15
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
water based timber oil.... what will they think of next....
world llc is offline
The Following User Says Thank You to world llc For This Useful Post:
Tinstaafl (05-15-2012)
What to put on the Exterior of a Timber Frame Markon Painting & Finish Work 6 12-13-2011 10:11 PM
New to this forum but not working with wood/construction. Jim_Rogers Introductions 27 11-12-2011 11:13 PM
Nailing wood timber flooring on subfloor? Jean-Marc Flooring 8 05-25-2011 01:23 PM
Insulating a timber stud cavity wall - Query? AlanC Insulation 1 05-08-2010 11:58 PM
Timber costs? Medway Handyman Decks & Fencing 0 10-28-2008 03:53 AM
