Aura On New Sheetrock W/o Primer
Old 11-19-2009, 09:59 PM   #1
Metro M & L's Avatar
Trade: Painting & Flooring
I was talking to a bm rep today who said that you can prime new rock with aura, top coat and you're done. He said that they just did the ikea stores this way. Any thoughts on this method?
"Yeah... It's worthy of a sig quote."
Metro M & L is offline
Old 11-19-2009, 10:17 PM   #2
NJPainter's Avatar
Trade: Painting-Drywall-Restoration-Pressurewashing-
Re: Aura On New Sheetrock W/o Primer
I'd say it's better than using it over previously painted walls... It's thick and needs to be re-rolled after a careful initial roll to get a non-obnoxious stipple. At least that's my experience with the stuff. Excellent coverage though.
NJPainter is offline
Old 11-19-2009, 11:45 PM   #3
Rcon's Avatar
Trade: wood finishing
I haven't had the opportunity to try Aura yet but looking forward to giving it a whirl. My BM rep told me the same thing - 1 coat primer and 1 coat Aura and the job is done (on new drywall). I'm not certain that he meant using Aura as the primer, however, and I find it hard to imagine priming raw drywall with a thick paint such as this. I wouldn't be surprised if Aura has an actual primer product (i.e. a thinned down version for prime coating). I shall have to investigate further.
Rcon is offline
Old 11-20-2009, 06:43 AM   #4
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
I do not believe I would prime new drywall with $55 a gal paint and I also do not believe in primer and paint in the same can, but hey what the hell do I know?
chris n is offline
The Following User Says Thank You to chris n For This Useful Post:
ProWallGuy (11-21-2009)
Old 11-20-2009, 03:04 PM   #5
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
Because of the high cost, prime walls with a cheap primer tinted to match the finish color, then topcoat with Aura.
Or you can use 2 coats of Aura over raw drywall. It seems like I use 2 coats of mid grade finish paint (SW 200 line) over raw drywall all of the time anymore.
We did a large new office building with 9 foot walls only using 2 coats of Aura over the new drywall. This is what the GC and customer wanted and spec'd the job for. Looked good. We even used Aura to topcoat the 9 food hollow metal doorframes. Also looked good.
vandyandsons is offline
Old 11-20-2009, 03:50 PM   #6
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
Thats how I do it, 2 coats of Aura and your done! I know it is cheaper to prime with a cheaper product but the results of the look is so much better with just Aura!
Mr. Mike is offline
Old 11-20-2009, 06:51 PM   #7
vandy
Mr.Mike
I believe that a decent paint (let alone great like Aura)seals the raw drywall a lot better than regular cheap primer. Nicely sealed drywall yields a nice uniform sheen on the finish coat.
Old 11-20-2009, 10:50 PM   #8
NJPainter's Avatar
What did you prep the hollow door frames with?
Old 11-20-2009, 10:54 PM   #9
NJPainter's Avatar
Old 11-20-2009, 11:55 PM   #10
House Painters Reading PA
4thGeneration's Avatar
We have actually applied 2 coats of BM Aqua Pearl on new sheet rock and it worked out well. We would have the rock wet moped after it was sanded and turned out awesome. I would have preferred a undercoater enamel primer, but thats what the builder had it specs at.
House Painting and Roof Cleaning by Sutton provides
House Painting Services in Berks county PA
for all Interior and Exterior Projects
484-334-3999
4thGeneration is offline
Old 11-21-2009, 01:55 AM   #11
I'm not familiar with wet mopping. I assume that just means you took a sponge and lightly wiped off all the dust and let it dry before painting? Are you saying you did do it and it made a difference?
Old 11-21-2009, 07:30 AM   #12
NJPainter's Avatar
I'm not an expert user of sponges, although I've seen the difference in sponge sanding makes on a massive residential job I worked several years ago. IT was the most professional drywall job I've ever seen. They left the house dust-free, even in the holes, with no scratched paper and minimal touch-ups.
On the basement job, which was approx 20x25 I used a wet cloth to get the walls tip-top before applying 2 coats of Aura. The color match between new and old wall were excellent using only two coats of a deep base over the mud and drywall. Phenomenal. Really
Old 11-21-2009, 06:47 PM   #13
vandy
What did you prep the hollow door frames with?[/quote]
primed with pigmented shellac if I remember correctly, topcoated with Aura.
Old 11-21-2009, 09:44 PM   #14
When we worked on new construction we had the luck to go behind the best drywall company I have ever worked with. They guys were redneck and out there. They lived on the edge, were loud, but so much fun. If we filmed it we could have been the number one reality construction show really.
Anyhow, wet mopping does make the difference. Even paint new construction, but you could see the grooves the sandpaper made(Burned up the rock)? Well, wet mopping cures all that and keeps everything dust free. We were the only company I knew that dusted all their walls prior to painting and the touch up was so much better. With wet mopping we did not have to dust a thing. They had these huge microfiber mops and were quick. We actually could breathe after we walked onto the project.
484-334-3999
Old 11-22-2009, 09:29 PM   #15
nick@nite
THINKPAINTING's Avatar
Look at my pics of aura in my profile, slate grey, ruby red being rolled out.
Aura has its place for medium and deep base colors both interior and exterior....
THINKPAINTING is offline
Old 11-23-2009, 09:10 PM   #16
Jeffrey Watson's Avatar
Trade: carpenter
I'm not sure I want to put $15.00 PRIMER UNDER $55.00 PAINT.
Jeffrey Watson is offline
Old 11-24-2009, 05:28 AM   #17
chris n's Avatar
Who said anything about $15 primer?
chris n is offline
Old 11-24-2009, 05:01 PM   #18
...jammin
slickshift's Avatar
Trade: Rock Disciple
From another forum:
Originally Posted by slickshift
With Aura on new drywall, as with most "self-primers", the finish will still come out better if primed first
(not so on plaster...just go right to it in those cases)
However, Aura does have other advantages
Like ultra-low VOCs, burnish-resistance, wash-ability, durability, color-retention, and downright beautiful display of rich and/or complex colors
You might "get-away with" one coat over tinted primer, but the other attributes could suffer
Signature Quote
slickshift is offline
rambling on about Benjamin Moore and Aura frankcanpaint Painting & Finish Work 16 04-04-2009 11:00 AM
sheetrock vs. plaster in bathroom post and beam ceiling Bunc General Discussion 2 03-16-2009 09:34 AM
Short Review Of Aura Paint Riverside Paint Painting & Finish Work 30 03-07-2009 08:50 PM
can't get rid of bad primer smell....help please Zeebo Painting & Finish Work 17 12-10-2008 06:39 AM
Is anybody using SHEETROCK Tools? Big Bison Tools Drywall 1 11-01-2007 07:47 PM
