Old 11-14-2007, 12:52 PM   #1
Trade: drywall
Another airless question?
I've been watching for a good deal on a used airless. Now, I have an opportunity to buy a Graco 1095 in good condition at a great price.
This is certainly more machine than I need, but about the same money as smaller pumps I've found. Other than weight , is there a down side to this kind of overkill? Or should I grab it?
Thanks....
Gary
garyoutwest is offline   Reply With Quote
Old 11-14-2007, 03:03 PM   #2
Brocktologist llc.
Brockster's Avatar
Trade: drywall
I was recently in the market and was thinking small at first then considered that the smaller ones would have trouble pushing some of the thicker primer and paints. You can also add more hose to the larger pumps so you're not having to move the pump all the time.
I say go for it.
Brockster is offline   Reply With Quote
Old 11-14-2007, 03:30 PM   #3
premierpainter's Avatar
Trade: Painting Contractor
Always buy the biggest pump that you can afford. You will be much happier in the long run. Check out e-bay. They tend to have lots of big good sprayers.
premierpainter is offline   Reply With Quote
Old 11-15-2007, 03:28 AM   #4
Workaholic's Avatar
The 1095 is a great pump, it can be turned down like a 695 for finer finishes, then cranked back up for serious out put. I recommend the bigger pump, you will thank yourself later without a doubt.
Sean
Workaholic is offline   Reply With Quote
One more airless power roller question steve-in-kville Painting & Finish Work 5 09-19-2008 10:09 PM
Can anybody answer this question? Chance Drywall 25 10-13-2007 08:22 AM
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 13 08-25-2006 07:49 AM
