Alligator Looking Trim
This is gonna probably sound stupid to some but......
I scraped, wire brushed and even sanded the trim on a house till it was smooth. Now that I put a coat of primer on it it still has the apperance of alligator skin. Any tips on what I could do differently (short of stripping it to bare wood) or a tip that I can do after the primer coat would be appreciated. |
Re: Alligator Looking Trim
What type of primer did you use? Are you describing what looks like lots of little cracks? If so, this usually is an issue of incompatable finishes. Usually this happens when you apply a strong finish (i.e. epoxy) over a finish such as oil base paint. If not cracks, it will sometimes cause the under finish to bubble. This should not happen with your normal residential products. You can use a universal primer such as UMA. Is this interior or exterior?
Electro Last edited by Nathan; 09-08-2005 at 11:07 PM. |
| Old School Trim ??? | mobjack68 | Finish Carpentry | 27 | 09-17-2008 06:26 PM |
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
| Trim out of order, need some advice | PaulG | Painting & Finish Work | 8 | 03-02-2007 03:49 AM |
| Glossy Trim | jimbo123 | Painting & Finish Work | 5 | 02-06-2007 06:46 PM |
| hvlp vs. airless for spraying trim | Traditions | Painting & Finish Work | 13 | 08-25-2006 08:49 AM |
