Old 04-05-2007, 10:48 PM   #1
all day spraying
I will have a couple of days of nonstop spraying. wondering how do you guys leave your paint and sprayer when you go for lunch or have to leave for an hour and then continue spraying...
bgpainter is offline   Reply With Quote
Old 04-06-2007, 05:57 AM   #2
Trade: Painter
I set the gun down and walk away. When I come back, I pick the gun up and start spraying again. If it is overnight, I might release the pressure on the pump, but that is it if I am spraying the same product the next day.
DeanV is online now   Reply With Quote
Old 04-06-2007, 06:13 AM   #3
painterofeverything
Trade: residential painter
Send a message via Yahoo to painterofeveryt
if I stop for more then 5 minutes, I always dump my pressure in the pump,and set the gun in a 5 of water...over nite same thing.
painterofeveryt is offline   Reply With Quote
Old 04-06-2007, 06:44 AM   #4
KellyPainting's Avatar
Trade: Painting Contractor
Same for me.... 5 gallon bucket of water.
KellyPainting is offline   Reply With Quote
Old 04-06-2007, 06:45 AM   #5
Trade: Painting & Remodeling
I somtimes like to set the gun in some water to keep the tip from drying up. when its really hot that is.
BMAN is offline   Reply With Quote
Old 04-06-2007, 07:07 AM   #6
Painting Contractor
Humble Abode's Avatar
Send a message via AIM to Humble Abode
I did that once and my gun started to rust, literally overnight. What kind of guns do you use? Mine was a Graco.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline   Reply With Quote
Old 04-06-2007, 10:08 AM   #7
Trade: Painting and decorating
We never leave pump filled overnight. For quick rest dunk it in a 5 . Titan rusts quickly too.
Leader is offline   Reply With Quote
Old 04-06-2007, 10:33 AM   #8
Painting Contractor
Do you know why you don't leave it filled over night? I have heard that it is never good to leave the pump under pressure for to long. And again I have heard painters say they leave it under pressure all the time...
Also if it isn't under pressure, the paint will begin to cure in the lines, correct?
The NAPP
Old 04-06-2007, 12:29 PM   #9
Trade: painting contractor
I like to release the pressure from the rig for saftey purposes. Always have this fear that some one will mess with the gun. I will keep snorkel in paint and cover with plasic and stick the gun in a gallon of water.
gary
gary lee is offline   Reply With Quote
Old 04-06-2007, 12:41 PM   #10
Paint brushes
I was at a pro show yesterday and was talking to a purdy rep. I said I have used a wire brush to clean my brushes after a day of painting. The rep looked at me in horror and said never use a wire brush to clean your brush. I have been painting for 15 plus years and me and everyone I have worked with our around has used a wire brush to clean there brushes. After talking to the Purdy rep it made sense to me why you should not use a wire brush for cleaning the brush. It never seeks to amaze me how the activity of learning never stops. I am going to try to stop using the wire brush but will be difficult because it is engrained in me. How do you guys clean your brushes?
Gary
Old 04-06-2007, 03:00 PM   #11
Painting Contractor
I use one of those small red bristle brushes sometimes, only when I have been using the same brush all day and have dried paint on the hilt. Otherwise just water and my hand.
The NAPP
Old 04-06-2007, 03:19 PM   #12
Heheh,who is that masked man?? LOL!
boman47k is offline   Reply With Quote
Old 04-06-2007, 08:31 PM   #13
Workaholic's Avatar
I agree
Sean
Workaholic is offline   Reply With Quote
Old 04-06-2007, 09:40 PM   #14
General Contractor
Trade: General Contracting and Painting
Gary
I've always used a wire brush. So what did he recommend as the correct way?
jensenconstruction is offline   Reply With Quote
Old 04-06-2007, 09:48 PM   #15
Trade: Hanger taper finisher painter
I had a co worker that always left his pump under pressure. He came back to the job the one morning to a pin hole leak in the hose. The pump wasnt on and just the pressure alone made the paint shoot out like silly string all over the place.
johnjamesalaska is offline   Reply With Quote
Old 04-06-2007, 10:26 PM   #16
Educated Applicator
MarvinWilleyJr's Avatar
Trade: Painting & Fine Finishes
Send a message via AIM to MarvinWilleyJr
We let the presure off, unplug the rigs, and get the lines together ( not rolled up, but just out of the way ).
As for overnight..............they are cleaned up daily. Never left in paint overnight.
MarvinWilleyJr is offline   Reply With Quote
Old 04-07-2007, 08:07 PM   #17
RCPainting's Avatar
Trade: Painting in Utah
I agree!
RCPainting is offline   Reply With Quote
Old 04-07-2007, 10:38 PM   #18
Workaholic's Avatar
Gary
I would like to hear what he told you too?
Seeing how he is a purdy rep my guess is he told you to use a spinner and i brush comb, with warm water and a mild detergent.
Sean
Old 04-08-2007, 09:47 AM   #19
How do you leave your brushes over nite? WE don't we clean them.....
You should clean your sprayer at the end of every day also.
leaving it in water is fine for a small amount of time... but water is not good for your rig for long periods of time.
Old 04-08-2007, 11:13 AM   #20
My custom title
Brushslingers's Avatar
Wasn't gonna answer since we are terrible.. .but, we leave pressure off and the gun in a 5 of water overnight or for lunch, never had a problem. We also have so many brushes that most of us simply toss em in the 5 and at the end of the week..... heh, and at times, left them dunked in paint overnight.
Benn
Originally Posted by Brian
Brushslingers is offline   Reply With Quote
Spraying pressure, tips and mostly technique bgpainter Painting & Finish Work 11 08-12-2008 10:39 PM
spraying has ruined my brush and roll estimating Traditions Painting & Finish Work 11 09-15-2006 03:31 PM
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 13 08-25-2006 07:49 AM
Spraying Outside Corners with Spray Shield remodelnut Painting & Finish Work 3 02-01-2006 07:30 PM
