Old 04-15-2005, 09:37 PM   #1
Trade: painting
airless sprayer,help
It's spraying nice but is shooting small sploches out. I've adjusted presure cleaned it and cant think of anything else to do.
alysdave is offline   Reply With Quote
Old 04-15-2005, 09:48 PM   #2
Teetorbilt's Avatar
Are you straining your paint? Completely cleaning after every use? Using the right tip?
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 04-15-2005, 10:03 PM   #3
Trade: painting
not straining, will do, thanks
Old 04-15-2005, 10:31 PM   #4
Teetorbilt's Avatar
If it's any consolation, I learned the hard way too.
Albert Einstein
Old 04-16-2005, 10:29 PM   #5
Answere Man
Trade: Home improvents
Dave here are several guaranteed remedys the totality of them will insure spot free spraying.
1. Make sure the filter in the bottom of the gun is cleaned after each use.
2. Make sure the tip is the right size for the material being sprayed. Stains are finer tips than oil paint or latex 12 to 15 thousandths .012 to .015
3.Strain your paint with panty hose. I know this takes more time but we want it right the longer the gun works with out problems the more money you make faster.
4. Make sure the inlet strainer is clean too at the bottom of the syphon hose.
If you do all these things the gun will work fine.
One last thing if the spray pattern is fingering or not a consistant fan then the tip is worn out. Replace it. Apx 50 bucks.
:Thumbs: Answer Man :Thumbs:
Answer Man is offline   Reply With Quote
Old 04-18-2005, 06:16 AM   #6
Trade: House Painter
It does sound like you might need a new tip. I try to buy a bunch whenever I see them on sale.
Trey is offline   Reply With Quote
Old 04-18-2005, 09:06 PM   #7
Dripless
Trade: Painting and exterior wood care
A great supply for quality tips is http://www.paintersupplydirect.com/ The TriTech tips spray better than Gracos and last longer for $18. a pop.
Dale is offline   Reply With Quote
airless sprayer and generator gary lee Painting & Finish Work 14 05-11-2007 07:11 AM
Air assited airless sprayers tlneil Painting & Finish Work 1 03-31-2007 03:38 PM
Airless sprayer DROPLETS Kashmir Painting & Finish Work 11 01-07-2007 07:45 PM
Air Assisted airless spraying SeaSpray Painting & Finish Work 9 09-19-2006 04:10 PM
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 13 08-25-2006 07:49 AM
