Air Compressor Or Turbine For HVLP?
Old 11-04-2008, 01:29 PM   #1
Rob Vinnedge's Avatar
Trade: commercial building owner/contractor
I have been looking at the Capspray Magnum II gun w/cup and am wondering if I could save money by using my existing air compressor rather than buying the Spraytech turbine unit which is usually sold with it. Is there an advantage one way or the other?
Rob Vinnedge is offline
Old 11-04-2008, 06:04 PM   #2
Dash808's Avatar
Trade: This & That
Re: Air Compressor Or Turbine For HVLP?
It depends what you are using it for.
IMHO the turbine route is the way to go. It lays the material on better than an air assisted sprayer, especially for lacquers and eurethane's.
Dash808 is offline
Old 11-05-2008, 07:23 AM   #3
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
If you want to use a compressor, buy a conversion HVLP gun. I recommend the turbine / gun matched unit.
BACKWOODS is offline
Old 11-05-2008, 02:40 PM   #4
By conversion, do you mean a normal HVLP gun with an added pressure regulator?
Old 11-05-2008, 04:15 PM   #5
DeanV's Avatar
Trade: Painter
No, coversion means it is an HVLP gun designed to be used with a compressor, not a turbine. Compressor supply LVHP air which must be converted to HVLP air.
DeanV is offline
Old 11-05-2008, 05:20 PM   #6
plazaman's Avatar
i debated this same topic, i ended up going with an iwata mini gun. never used it yet, so i cannot comment on the finish
plazaman is offline
