Advice On Potential Job
Old 03-22-2007, 05:16 PM   #1
72chevy4x4's Avatar
I have a real estate contact who wants a bid on a bit of fixup work on a property where the new owner (through will) lives many states away. The walls look as if they have not been washed in 30 years-no joke! The paint seems to match the old Fridgidair 50's style range along with galvanized pipe that needs removing. Back to the walls-they could easily be sprayed b/c the carpets will come out (green shag in one room!).
Does anyone have experience in coming into a situation where the walls were in horrible condition? What would you recommend to make them suitable for accepting paint? If you have any other recommendations, I would love to hear them.
72chevy4x4 is offline
Old 03-22-2007, 05:40 PM   #2
farrellpainting's Avatar
Trade: exterior painting contractor
Re: Advice On Potential Job
Clean them!
farrellpainting is offline
Old 03-22-2007, 05:47 PM   #3
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Powerwash them
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 03-22-2007, 05:55 PM   #4
Yeah what ron said, LOL
When your done, come back and ask how much $/sqft !
Old 03-22-2007, 06:34 PM   #5
My custom title
Brushslingers's Avatar
Heh, little TSP in a pumpup.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 03-22-2007, 07:16 PM   #6
Sorry Chevy, It's just that I've never heard of a HI contractor that didn't know how to clean a wall?
Old 03-23-2007, 12:52 AM   #7
Joewho's Avatar
Trade: Painter
Well, what exactly is on the walls? smoke? grease? just plain old schmootz from sitting for so long?
The kitchen will undoubtdly have grease and oils. Around the stove you might have to actually scrape off a layer of grease and then wash with a de-greaser, like tsp etc.
The bathrooms will have soaps, aresols and other bathroom products. That needs to be washed down carefully, since some of those products act like silicone and show through he paint.
The rest of the house, you might get away with sanding the walls down and priming with water based primer. I would get a couple of cans of spray kilz for inks, crayons and other marks that paint won't cover.
The kitchen and bath should be primed with a solvent based primer after washing.
Joewho is offline
Old 03-23-2007, 01:36 AM   #8
Super B
skyhook's Avatar
Seriously, I hired a painter and told him to wash the walls with TSP. He refused and sanded the walls. Made a huge mess and after 3 coats the yellow was still showing through. I paid him to date and sent him down the road.
skyhook is offline
Old 03-23-2007, 01:56 AM   #9
Clean&rinse, sand if glossy finish, prime if color is drastically different, and then top coat with finish accordingly! If you don't know that and your doing business as a contractor, well then you should probably go work for a REAL painting contractor to at least learn the ropes first, before you go out on your own!My 2c!
Old 03-23-2007, 05:23 AM   #10
Frankawitz's Avatar
I would take a 5 gallon bucket of HOT water dump a box of TSP into it take a pole sander put a 3M scrubbie pad on it and mop the walls and ceiling then take a sqweegie and then mop the floors, you could also put some of TSP in a garden sprayer. spray the ceilings and walls. Good Luck
Frankawitz is offline
Old 03-23-2007, 05:54 AM   #11
Dump a box of TSP in it?Are you out of your f@#$ing mind?LOL!
Old 03-23-2007, 07:25 AM   #12
...jammin
slickshift's Avatar
Trade: Rock Disciple
You could wash with TSP...or anything at this point...lestoil, simple green...doesn't really matter with that much dirt/grease/gunk
You just need to find out if that stuff is coming off, or if it's tar/nic from a smoker
That's another issue
Signature Quote
slickshift is offline
Old 03-23-2007, 06:57 PM   #13
MakDeco's Avatar
Trade: Painting Contractor
Hey 72 why don't you get a job w/ Farrell he sounds like he'd be great boss!
MAK Deco
MakDeco is offline
Old 03-23-2007, 07:14 PM   #14
Building Contractor
Chippewabuilt's Avatar
Trade: Building contractor
if real bad you can drywall over with 3/8 drywall as long as it ant moldy
Chippewabuilt is offline
Old 03-23-2007, 08:43 PM   #15
72chevy4x4's Avatar
Thanks for the tips Ferrel. From your previous posts, it seems you have a bit of growing up to do. You've got a whole year in the business-congradulations
For the serious guys out there, scrubbing every single square inch of surface area is a daunting task and I'm hoping to find an easier method. While a power washer would do the trick, hardwood floors are under the carpet. Some walls have layers of dirt, others have residue from a smoker. The worst seems to be a large bedroom which seems to have spots on the wall which I've seen in more humid environments-although I'm not sure if that is the source (shaded lot w/ lots of trees and a humid area though).
Thanks for the pole sander tip Frankowitz, I like that one. A tree/weed sprayer may speed up the process too.
Old 03-23-2007, 08:52 PM   #16
...jammin
slickshift's Avatar
Unfortunately scrubbing every square inch would be part of the solution
If it's too hideous, or time consuming, I sub out the cleaning to a pro cleaner and build that into the bid
It's really got to be as clean as you can get it
It sounds like it's gonna have to be oil-primed too
Zinsser's Cover Stain (or similar) for those nic/unsub stains
Signature Quote
Old 03-24-2007, 02:32 AM   #17
JNLP's Avatar
Trade: Painter
JNLP is offline
Old 03-24-2007, 02:32 AM   #18
rocco's Avatar
Trade: handyman
It sounds like a very old house from your description. Don't forget to check to see if it is lead paint. Good luck.
rocco is offline
Old 03-24-2007, 06:13 PM   #19
Joewho's Avatar
Trade: Painter
I'm not a big fan of water running down my arms either. What I posted would be typical for a really bad apartment. A sealing primer will help avoid washing every square inch. Especially the ceilings. Most stains on walls aren't as bad as they look. Anything that looks oily will be a problem. Everything else will usually cover with primer after pole sanding.
Joewho is offline
Advice with room addition and blueprints A.W.Davis Remodeling 35 03-28-2007 07:32 PM
Advice on mounting Steel angle irons. turbomason Masonry 12 03-04-2007 12:47 AM
Need Advice on Poly-Urethane Issue realpurty2 Construction 5 08-09-2006 11:29 PM
Advice on Becoming a Plumber robertr25 Plumbing 2 02-24-2006 04:30 PM
contact with potential customers AHS Marketing & Sales 13 02-13-2006 02:02 PM
