Advice For My Titan 440i I just got a new Titan 440i in yesterday. haven't used it yet, and have only used another sprayer like 2 times.. And that was just using the power roller, not even spraying.. Is there anything I should note before using my new Titan? I don't wanna mess anything up with it, so Im trying to be extra careful. What things can I not spray with it? Can I spray primer? Also, I got the skid model, so is ther anything I can do about the hose or do I just have to roll it up and use it like that? I was thinking on of them extension cord roller thingys, but not too sure if it will work with the pressure hose. help a brotha out
Painter S.Illinois
Trade: Painting Contractor
Re: Advice For My Titan 440i
Be sure to add a few drops of oil before using......be sure to clean it after every use an airless sprayer is a decent investment..i take my filters out and clean them after every use.....clean with warm water if possible if using latex and mineral spirits if oil based paints.I use a small stiff nylon brush to clean the tips and gun.As far as hose goes they are just a pain in the butt to handle. I have an upright and a skid sprayer money well spent on the upright easy to move around...dont like the skid type.
yeah I just sold an Graco XR9 tallboy.. I got the skid b/c I like the size of the machin. I can take it inside if needed or what not. Plus, Im working out of a Toyota Camry, so not too much room for all my supplies... Haha. Its been working out real nice for me though.
Painter S.Illinois
I have two spray techs now but getting ready to buy the Titan xi after researching them I think they are the best buy for the money.
Painter S.Illinois
Hows the power roller working out for you? I have it on my spray tech but never used it...wondering how well the power rollers work and do they save you time.
Yeah I think they save some time, you odn't have to fool with dipping the roller for paint, however its a bit awkward having the roller on an extension wand. You don't get the maneuverabilty like you would a regular roller. Im thinking about trying out an 18" roller for my bigger rooms. Does that work out pretty good for you guys?
Painter S.Illinois
18" rollers with 3/4 nap for larger rooms with orange peel work well for me allows you to get more material on the wall........
BLUE JAY PAINTING
Trade: painting
Make sure like they said to use the piston lube before each use, it will extend the life of the packing and save the rod and costly repairs later. Also when your done using the unit for the day make sure to flush it out well with water/ or paint thinner if oil based. Never leave water in the pump for more than a day or so, if your not going to use it for a while store it with the titan LS-10 solution your pump probably came with a small botte of it. if your going to store your pump for a long time like months use paint thinner with a little motor oil added and just prime it with that to prevent rust.
And remember to check the filters often there is one in the gun handle and one under the pump, the filters are threaded in, but they are a reverse thread. Good Luck Joe |
ok can I use pump armor instead of the titan spray stuff? I had a graco and just bought a big bottle of it?
Trade: painting and carpentry
yup.
#11 | |
Professional Painter
Trade: Owner/Operator
Re: Advice For My Titan 440iQuote:
The most important thing I can recommend is to get 2 hoses. 1 for latex, 1 for oil. You need to clean filters, hoses, pump, outside of unit carefully and thoroughly after every use...unless you are using the same product on a job, just let the paint sit in the whole unit and hose. These are incredible machines and some of the best out there, in my opinion. Make sure you have a bunch of tips, extra filters, etc...good luck--how's working out of a car? Never did it.
Rich |
BLUE JAY PAINTING
Trade: painting
forgot to add you can spray just about any kind of oil or latex products right out of the can. You cannot spray however block filler and elastomeric products. Worked on a few of these where guy's did spray these products and it just kills the pump.
The Titan and graco pump armour are basically the same product which is pretty much just antifreeze. Joe |
Haha. Working out of a car isn't too bad. I can fit everything I need on a pretty normal job... Toolbox, sprayer, decent size ladder, etc. When I have a job that calls for the big ladders, I have access to a 4Runner, but don't usually need that one. I got a big residential project coming up soon..... 19 foot ceilings.. I don't know what Im going to do about that one. I might need a crane to hoist me up that high.
Trade: Paint Contractor
Don't forget to connect to the power outlet
#15 | |
You better strain it first. Doesn't matter if it is brand new paint. Always strain, or you'll be stopping and breaking down your machine to find the clog. |
BLUE JAY PAINTING
Trade: painting
As long as you have a inlet strainer on it you should be fine unless your using some pretty cheap paint. But your right if you have the time to strain it then you forsure wont have any problems but if your spraying 5 gallon pails it may be a pain, most painters dont strain before spraying. INLET STRAINER IS A MUST THOUGH.
Ok you might be right... I DO have an inlet strainer, but was plagued by clogs on a brand new can of paint (SW Harmony). It was my very first time spraying. I strained every single drop since that time, and I stand by my insistence on straining (except on the toilet).
I mean can you imagine getting your machine all set to spray, and then 10 minutes in you're sputtering? And then breaking the whole thing down? Oh NEVER again, I say! |
#18 |
Trade: Home Renovations
How do you strain?
#19 |
Trade: Painting and Finishing
A strainer is the metal mesh thing that's on the endd of the inlet tube. I think titan calls it a rock guard. You can strain you paint befo re you use it with a paint strainer (looks like a big nylon weave bag) or a pair of panty hose. We use hose. It does a better job.
Pump mineral spirits up into the pump if you're going to store it for more than a week. During winter, pump spirits all the way through it. Never leave the system under pressure, and always buy Graco tips. Congrats on your new pump. May it last you a long time. Did you get the G-10 gun? That's a good gun. Better than the graco contractor II imho.
Steve Jones steve@jonespaintingonline.com Jones Painting Feel the difference service makes |
#20 |
painterofeverything
graco tips suck...in my humble opinion that is ,once I tried the tri-tech tips I have never used another brand of tips.http://www.tritechindustries.com/purchase.html
| Graco Ultra 395 or Titan 44ix???? | kenrie | Painting & Finish Work | 13 | 02-02-2009 07:08 PM |
| Advice with room addition and blueprints | A.W.Davis | Remodeling | 35 | 03-28-2007 07:32 PM |
| Titan 440ix | jself52 | Painting & Finish Work | 4 | 02-16-2007 12:52 PM |
| Looking for advice on selling my business | dumplin1078 | Marketing & Sales | 12 | 09-07-2006 06:37 PM |
| The Titan 440i | slickshift | Painting & Finish Work | 6 | 02-08-2006 08:22 PM |
