Hudson Valley
Trade: Restorative Painting
Acrylic Primer Exterior
Your opinions on the best primer [acrylic] for an exterior, substrate is red cedar [don't scream oil just yet] that has been finished with a {so the owner tells me} an acrylic primer and two top coats. I see no evidence of bleed through, however there are darker spots where the stainless steel nails are.
Against my advice he insists on everything receiving a primer coat before finish coats. I'll be contacting California and Western Red Cedar Assoc. for their opinions also. [Ya didn't think I'd trust you alone ]
www.blueskiesrestorations.com There's some top class people on this forum,........and then there's me...Touching cloth. |
#2 | |
...jammin
Trade: Rock Disciple
Re: Acrylic Primer Exterior
I won;t scream oil, except on the nail heads
Just dab some on there No need for it anywhere else at this point
Signature Quote Quote:
Hudson Valley
Stainless steel nails: Why the need for oil?
Painting Contractor
Re: Acrylic Primer Exterior |
Trade: painting contractor
I agree with slick why not just spot prime with the oil where the nail heads are bleeding (XIM or coverstain)? Do I understand you right in that the homeowner wants the entire job to be primed in addition to the problem areas? Seems like overkill but if this is the case I would use Zinssers 123 for an acrylic primer.
Gary |
Hudson Valley
Thanks for the info on the nails, agree its overkill. Have a "I know better than you" customer. Building a consensus before I commit.
The voices in my head are starting to whisper walk away!!
| Should I use paint or stain for this exterior | Miniroller | Painting & Finish Work | 8 | 03-29-2010 12:29 PM |
| Primer questions | rebar17 | Painting & Finish Work | 14 | 10-25-2007 09:51 PM |
| best exterior latex primer? | toddcla2002 | Painting & Finish Work | 18 | 11-05-2006 08:03 PM |
| Primer needed on metal garage door??? | Zeebo | Painting & Finish Work | 11 | 08-19-2006 05:35 PM |
| Flat roof over garage leaking under exterior walk out door | IHI | Roofing | 18 | 05-30-2006 10:28 PM |
