Acrylic Floor Paint On Deck
Old 09-08-2007, 09:54 AM   #1
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
We have a customer who has coated her deck (properly weathered and cleaned) with Zinsser 1-2-3 and then Pratt & Lambert's Withstand Acrylic floor finish. She put a coat of 1-2-3 on and let it dry a couple hours as per the instructions on the can. Then they applied one coat of paint, waited 2 days and applied another coat of paint. The deck is raised off the ground several feet and has plenty of airflow. The bottom is not coated. We've had no rain and warm nights for quite a while. However I got a call today from them telling me the deck feels sticky. Considering the conditions and products used and the fact the last coat has been drying for a week, I can't think of what would be the problem. It is a deep color with a lot of tint. Is there anything else I might be missing? I'd usually say moisture or each coat was too heavy with too short a dry time. Everything seems done by the book though. Also the railings are fine, it's just the deck surface. Any input is appreciated.
gideond is offline
Old 09-08-2007, 10:08 AM   #2
MakDeco's Avatar
Trade: Painting Contractor
Re: Acrylic Floor Paint On Deck
Why the 123 on the floor? I didn't think thats too be used on floors? Aren't the floors paints made to be directly on to the floors? If and when I had to prime a deck for solid color I used an oil primer that says can be used on horizontal services.
MAK Deco
MakDeco is offline
Old 09-08-2007, 11:19 AM   #3
gideond's Avatar
According to P&Ls label it says to prime with a 100% acrylic primer first. I never would have recommended that anyone put this type of system on a deck in the first place. If they really wanted acrylic I'd opt for a solid stain. Someone else here evidently sold them this system. And according to P&L it should work fine. I still can't come to terms with using any sort of actual paint on a deck though. Railing maybe, but not the walking surface. I've heard of too many problems.
On a related note, I just looked at the 1-2-3 can and yes it says not to use it on decks or walking surfaces. I have seen it used this way in the past, but only on concrete and it never had any issues. Wood and concrete are two different beasts though. As soon as I figure out who sold them this I'll have some choice words.
gideond is offline
Old 09-08-2007, 12:12 PM   #4
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Yep, without closely guarded maintenance, that will be a peeling mess sooner than later. Sounds like something a painter would recommend
Slow curing almost always means one thing.. application error
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 09-08-2007, 02:04 PM   #5
welovepainting's Avatar
Trade: Professional Painting Contractor
we use armour seal tred plex from SW it is an acyrlic latex acts like a epoxy but its pretty thin. you can scrcth it with a knife it doesnt budge. We never use latex primer always oil...
House Painters Commercial Painting Contractors Cleveland, Ohio
http://www.welovepainting.com
http://www.cleveland-ohio-painting-contractor.com
welovepainting is offline
Old 09-08-2007, 08:14 PM   #6
gideond's Avatar
Get this. I just looked as the Withstand can again and it turns out I was wrong. They DON'T recommend 100% acrylic. They recommend a normal Latex house primer under it. Something is seriously screwed up about their recommendations. I'll have to call the tech department Monday and try and figure out how to proceed. I think the rep needs to go have a look at it. Technically, even though I wouldn't normally recommend this system myself, it is a valid application by the manufacturer's instructions. So I'll let P&L deal with it.
gideond is offline
Correect Deck ?'s Robert and others IHI Decks & Fencing 9 05-21-2008 10:45 PM
Dry lower deck stuff frostyfrost Decks & Fencing 12 05-19-2007 07:59 AM
Cedar Deck Prep Problems Larman Painting & Finish Work 2 05-04-2007 05:31 PM
Riverside deck Nick H Decks & Fencing 16 04-23-2007 06:59 PM
