Old 09-22-2008, 11:07 AM   #1
Trade: painting and refinishing
acid staining questions
I've been wanting to get into acid staining for a long time. We just build a house and i thought my basement would be a perfect place to practice. I plan on using a light and a dark color. From what i can tell after I spray the surface with the acid I scrub it in. How did I get the "marbled look" of the color. will the brush marks show up? Do I do the entire surface with the lighter color and then just spots with the darker. Any information would be appreciated.
Traditions2 is offline   Reply With Quote
Old 09-22-2008, 11:15 AM   #2
genecarp's Avatar
no need to scrub the acid in, you will however want to etch the floor prior to staining, it will open the floor up, and allow the acid to do its thing. the effect you are looking for comes from overlaying different colors in a random fashion. call the guys at sealant depot, tell them concrete central refered you, they will help you out, they are good guys to deal with. good luck G
genecarp is online now   Reply With Quote
Old 09-22-2008, 12:04 PM   #3
H and C 's website says you don't need to etch? They also say to scrub it in with a brush. However, I'm not sure that would give the look of marbeling. What is the best way to etch the floor?
Old 09-22-2008, 12:16 PM   #4
genecarp's Avatar
there are several different methods to floor staining, the more you research, the more you will understand this. i have achieved excellent results without scrubbibg the stain in, etching can be done with muriatic acid, or another more user friendly product called SIMPLE BLUE, sealant depot has it all.
PS, the staining is first part, your head will really start spinning when you get to the sealer selection....
?? staining parquet flooring rservices General Discussion 4 08-19-2008 06:27 PM
Sump Pump questions WhitlockConst Plumbing 3 08-17-2008 11:32 AM
Pricing questions Brian Painting & Finish Work 3 10-13-2007 08:38 AM
Acid stain project 6stringmason Masonry 19 02-18-2007 05:40 PM
Water staining on exterior stucco cutnroller Painting & Finish Work 13 03-17-2006 05:22 PM
