Trade: Painting and wallpaper contractor
18" Roller Set Up
I have been using the 18" roller set up by Wooster. The bucket is called a "wide boy". Any thoughts on using an 18" roller set up? If you do, what brand like Wooster or Sherwin William brands do you prefer??
Thanks Sal Last edited by salmangeri; 06-19-2010 at 02:30 PM. |
Trade: commercial building restoration
Re: 18" Roller Set Up
18" is the best all day long. it will make your arms strong after a 12 hour day.
wooster frames are the best - you can use any 18" sleeve, its the painter that makes it look good not the roller sleeve. Make sure you "freak it out" - Cleveland painting term for using masking tape to pull all the loose hairs off of a cheap roller sleeve. |
we've been using the SW contractor series 18" sleeves, works well
#4 | |
...jammin
Trade: Rock Disciple
I have not had good luck with this style frame:
![]() ...in fact, I've had bad enough luck with several, that I wouldn't use them again nor could I recommend or suggest them This kind seems just fine: ![]() However, my new favorite is The Hulk: ![]() ![]() I was worried about the plastic clips, but so far so good
Signature Quote Quote:
| One more airless power roller question | steve-in-kville | Painting & Finish Work | 5 | 09-19-2008 11:09 PM |
| Trouble with roller lines using 18" wooster | KJLinden2002 | Painting & Finish Work | 16 | 01-01-2008 09:55 AM |
| Titan power roller... My first impressions | steve-in-kville | Painting & Finish Work | 0 | 06-17-2007 11:22 AM |
| 18" Roller Attachment for Sprayer? | all-pro | Painting & Finish Work | 3 | 06-01-2007 08:14 AM |
| 2 Power Roller Options... which is better? | kenrie | Painting & Finish Work | 8 | 10-12-2006 04:19 AM |
