15,000 Sq Ft Job...need Some Bidding Help
Old 12-21-2006, 11:01 AM   #1
Pure Vision
SHAWNPAINTS's Avatar
Trade: FLOORING PRO / PAINTING
I need help with this estimate. It's a 15,000 sq ft building. Brand new drywall, 40ft ceilings, no trim. It is going to be a gym. Im going to spray it. Please let me know what some of you pros would charge. Thanks.
SHAWNPAINTS is offline
Old 12-21-2006, 05:36 PM   #2
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Re: 15,000 Sq Ft Job...need Some Bidding Help
a lot
keep in mind you will need a scissor lift and someone else with you--so many factors here...are the floors done? I sure hope not..are there metal beams across the top? are the walls concrete?
shoot us a bunch more info, so we can Really help you!
Rich
Richard is offline
Old 12-21-2006, 05:46 PM   #3
Don
donb1959's Avatar
Trade: Paint Contractor
$4.00 per sq ft should cover it.
I fish therefore I am
http://www.shimmerz.biz
donb1959 is offline
Old 12-21-2006, 08:30 PM   #4
LennyV-NHSNOLA's Avatar
Trade: Residential Renovations/Remodeling
Is the floor plan 15,000sf or is that the total wall space you are painting?
EDIT - Ooops.. I read the post better and see it's a 15,000sf bldg. At first I saw 15,000sf job.
Will there be offices or other rooms or just the main auditorium walls? Is it 40' high all the way around or is there a pitched roof with the peak being 40'?
LennyV-NHSNOLA is offline
Old 12-22-2006, 06:27 AM   #5
Pure Vision
It's a brand new building. This friend of mine is going to make the bldg into a gym. The floors are not finished and it doesn't matter about the floor because after the painting is done he will be putting down this rubber like padding. It will run me around $600.00 for the scissor lift and around $1,000.00 for the paint. The whole building is 40ft ceiling. Looks like a perfect square. There are a couple of offices but thats what my helpers will be doing. Thanks again.
Old 12-22-2006, 06:37 AM   #6
Richard's Avatar
Shawn...ceilings?
the reason I ask is cause I've seen some really complex metal beam systems in some auditoriums...
Rich
Richard is offline
Old 12-22-2006, 10:34 AM   #7
Pure Vision
no ceilings....thanks
Old 12-22-2006, 12:21 PM   #8
tile mason
MattCoops's Avatar
I'll toss you a number - $1.50 / sq ft of wall paint.
That's one coat primer, two coats paint (sprayed)
no trim or ceiling
sounds like a 3 day job with one guy in a scissor lift
MattCoops is offline
Old 12-22-2006, 05:57 PM   #9
Richard's Avatar
cool, no ceilings...I'd be somwhere around $2-3 per square.
Rich
Richard is offline
Old 12-22-2006, 08:07 PM   #10
Dorman Painting's Avatar
Trade: Painting Contractor
Let me give you some advice about the material number you've figured up. If it's raw/bare concrete, it'll suck up paint at an unbelievable rate. I painted a five thousand square foot building that wasn't nearly as tall and it sucked up well over one thousand dollars of paint.
Of course I had to put three coats of paint on the walls, that's what the GC speced and quite honestly it needed the third coat. I'd say you'll have in the neighborhood of 4-5 thousand dollars worth of paint on this job. That's if the concrete is bare and you plan on making it look good. If you just plan on giving it one heavy coat and leaving it at that, it'll look like crapola and you'll still spend 1500 bucks.
Another thing, I don't see how you can could charge someone two dollars a foot on this thing. That would put the price at 30 grand for about 5 days worth of work. That wouldn't fly where I'm from.
Dorman Painting is offline
Old 12-23-2006, 05:30 PM   #11
Pure Vision
its not concrete, it is all dry wall. all of it is preped and ready to go. i know what you mean about concrete. i did a 2500 sq foot basement and it was amazing how much paint i used. thank you all for the advice.
drywall Bidding Chuckman Drywall 6 04-19-2009 12:15 AM
Bidding EDT Finish Carpentry 13 08-08-2007 09:34 PM
bidding a health club yogymon Painting & Finish Work 5 02-17-2007 09:04 AM
More on bidding.... mdshunk Marketing & Sales 2 09-14-2006 08:37 PM
bidding nailbanger138 Framing 0 11-20-2005 01:10 AM
