Wiring Addition
I am wiring an addition and have some NEC code questions - possibly you could help.
Kitchen: I have a Eat in area, then kitchen, then dining room (existing - newly wired). I have a 20 amp circuit in the dining room with only two outlets on it - not sure how that happened but.... - Can I use this to feed the Gas Range? - Can this circuit feed the range hood? - Can this circuit feed the lighting in the kitchen? - Can I use this circuit to feed the outlets in the Eat in Area I have a circuit pulled for 3 outlets in the living room - - Can this circuit feed outlets in the Eat in Area? - Can this circuit feed the Kitchen lights? I've read that the dishwasher and garabge disposal can and can not be on the same circuit. - Which do you prefer? - Can a seperate circuit to the garbage disposal feed the outlets in the Eat in Area? Bedroom: - Does each bedroom need its own circuit, or can they share circuits? - Do the bedrooms need AFCI circuits? BAsement: - Does an unfinished basement need wired for the rough-in inspection? |
#2 | |
Electrical Contractor
Trade: Electrical
Re: Wiring Addition
My comments in RED:
listen twice talk once!
Trade: electrician
Re: Wiring Addition
Concerning dish and disposal I thought since they were "fixed appliances with over an 1/8th hp motor they needed to be dedicated?
I am excited I might learn something today! |
Trade: Electrical
Re: Wiring Addition
BK, where do you fin this 1/8hp rule?
Trade: electrician
Re: Wiring Addition |
#6 | |
Fentoozler
Re: Wiring AdditionQuote:
Petey....how about the required GFCI outlet?
#7 | |
Trade: Plumbing & Electrical
Could it be this? http://www.contractortalk.com/showth...highlight=fart
"....And then we all switch places when I ring the bell" -Adrock
Trade: Electrical
Re: Wiring Addition
OK, then I stand corrected.
Yes, the one minimum required GFI protected receptacle needs to have it's rough-in inspected.
Trade: electrician
Re: Wiring Addition
Awesome - much appreciated
Re: Wiring Addition
Yes, its an unfinished basement. I'm going to put in a few lights and one or two outlets and call it a day.
Thanks again. |
Re: Wiring Addition
Should I wire that range hood into the circuit for the 3 outlets in the living room.
So that circuit would supply the 3 living room outlets, Kitchen and Dining room lighting, and the range hood. Is this ok? |
Fentoozler
Re: Wiring Addition
You should read petey's answer again.
#14 | |
Trade: Commercial Electrical Inspector
Read article 422.31 - Diconnection of permanently connected appliances. I believe this is where you came up with the 1/8 HP ordeal |
DiscountLowVoltage.com
Trade: low voltage wiring
Re: Wiring Addition
Wiring, will it ever end?
Fentoozler
Re: Wiring AdditionNext Tuesday is the end date. All wiring must be completed by then.
In the learning
Re: Wiring Addition
According to Article 300 in the 2008 NEC book, the kitchen must have two, that's TWO small appliance branch circuits and need to be GFCI protected, and can not supply other lines. Also, it must be 20 amp circuits. For the lighting, it has to be a separate circuit but the range hood might be able to be added. The bedroom, according to NEC AFCI are somewhat required, but it depends on the inspector to make the call. For this just call the inspector you'll be using and ask him about it. Also the bedrooms can be tied together, or seperated, depending in amp usage. In my house two rooms are together for lighting, but receptacles are on seprate circuits by room. The basement, since it is an unfinished basement, it must have at least on GFCI protected circuit. Hope this helps you out man, and good luck to you!
#18 | ||
And I do electrical, too!
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
#19 |
ampman
Trade: providing pathways for electrons and protons
Re: Wiring Addition
a carpenter wiring anything is not good
an army of sheep lead by a lion will defeat an army of lions lead by a sheep |
| 'Quick Wiring' question | nadonailer | Electrical | 85 | 05-31-2009 09:57 AM |
| Ripped out wiring | shed-n-deck | Electrical | 17 | 12-16-2007 12:55 PM |
| Advice with room addition and blueprints | A.W.Davis | Remodeling | 35 | 03-28-2007 07:32 PM |
| Garage - Protecting wiring installation | eastment | Electrical | 1 | 11-22-2005 02:52 PM |
