#41 |
Remodeler Extraordinare
Re: # Of Wires Allowed Under Each Neutral Screw
You da man Speedy!!!
Wheres Mdshunk btw? Did he get stuck in attic somewhere?
A.W. Davis Construction Co. http://www.awdavisconstruction.com/ Your friendly remodeling contractor |
#42 |
Electrical Contractor
Trade: Electrical
I think he is on a covert undercover electrical sting operation in the Arctic.
#43 |
Trade: electrician
im new to electicians school and was wondering if the nec will solve almost any problem an electican may have?
#44 | |
Trade: Super Electrician
Re: # Of Wires Allowed Under Each Neutral ScrewQuote:
Most problems are technical or mechanical in nature, that's where experience comes in. It takes years of experience to solve installation problems, once you have chosen a solution, now you must use your knowledge of the NEC to make sure your solution is code compliant. Good question.
#45 |
Trade: Master Electrican, Electrical Contractor
The code is written by wonderfully intelligent experienced men who know way more than us simple electricians. The code does not allow two neutrals under one screw in the neutral bus. That is unsafe. It does allow two or more neutrals under one wirenut in a junction box two feet away from the panel however. That is safe. I can see the difference, can't you?
#46 | |
Electrician
Trade: Electrical Contractor
Hopefully those neutrals in the wire nut are part of the same circuit. |
#47 |
Trade: Squirrel Handler
Yes it will and it makes a damn nice door stop as well.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
| 55 volts on both hot and neutral, what the heck!? | karma_carpentry | Electrical | 32 | 02-28-2009 09:12 AM |
| Need help with a shocking outside waterspout | Badoish | Electrical | 23 | 12-27-2008 04:18 PM |
| Shared neutral with a GFI | darren | Electrical | 21 | 03-03-2007 06:38 PM |
| Stretching wires 18 inches? | Mike Finley | Electrical | 34 | 11-30-2006 07:35 AM |
| Number of wires in switch box | remoguy | Electrical | 1 | 11-16-2006 10:02 PM |
