Nm Cable
Old 05-17-2008, 09:21 PM   #1
Nitro9119's Avatar
Trade: Electrical
Nm Cable
hi all i am bidding a job that is in existing building. It has a lot of nm cable in it and mc cable to. I dont know whit kind of cable i should be using for new work
Nitro9119 is offline
Old 05-18-2008, 07:55 AM   #3
nap's Avatar
Trade: sparky
Re: Nm Cable
If you are an electrical contractor in New York, you surely should know the electrical codes for New York.
You should know, or have access to, the codes for any jurisdiction you intend on working within. Anything less would simply be dumb. What happens if you bid in NM and get the job and then realize it must be in MC. Guess who gets to lose their ass on the job?
Educate yourself properly or don;t bid the work.
nap is offline
Old 05-18-2008, 08:08 AM   #4
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Nm Cable
Come on man. You can't seriously have "electrical" as your contracting trade in your profile and still be asking this question.
Speedy Petey is offline
Old 05-18-2008, 08:44 AM   #5
mickeyco's Avatar
Trade: Squirrel Handler
Re: Nm Cable
Where are you getting New York from?
mickeyco is offline
Old 05-18-2008, 08:45 AM   #6
mickeyco's Avatar
Re: Nm Cable
I'd use NW cable.
mickeyco is offline
Old 05-18-2008, 10:25 AM   #7
nap's Avatar
Trade: sparky
Re: Nm Cable
Umm, from this excerpt from the original post:
where I misread new work for new york.
dammit, I guess I need to be getting some new glasses.
So, ignore the New York comment but the rest remains.
nap is offline
Old 05-18-2008, 10:27 AM   #8
genecarp's Avatar
Re: Nm Cable
cat 765, all around, code in guam, and new york
genecarp is offline
Old 05-18-2008, 10:28 AM   #9
Re: Nm Cable
That's okay, OP proly meant
Newark!
neolitic is offline
Old 05-18-2008, 11:23 AM   #10
mdshunk's Avatar
Re: Nm Cable
If the original poster isn't run off already, there's a few clues that can help you decide:
*In one and two family dwellings, you can pretty much run NM where ever you want to.
*In larger than two family dwellings, you can run NM where ever you want to (normally) as long as it is concealed. If the building is constructed as a "fireproof" construction type, you can't run NM cable anywhere, and you must use a metallic wiring method. You can identify these buildings by the fire walls, fire doors, sprinkler systems, etc.
*In non-dwelling construction (commercial work), you can run NM where ever you want (normally) as long as it is concealed. You cannot, under any circumstance, run NM above the dropped ceiling in commercial work now. It must be a metallic wiring method. If the building is constructed as a "fireproof" construction type, you can't run NM cable anywhere, and you must use a metallic wiring method. You can identify these buildings by the fire walls, fire doors, sprinkler systems, etc.
These are just some rules of thumb that work pretty well, which can be modified by local rules and even, regrettably, at the whim of locals who just don't understand the rules. Realistically, when the project gets complicated enough that it's unclear to the electrician what wiring method you are permitted to use where, an engineer is normally involved. This complicated stuff doesn't normally sneak through plan review without an engineer spelling out how the thing is to be wired. That doesn't help a guy that's trying to prepare a budgetary estimate before plan review, however.
mdshunk is offline
Troubleshooting ethernet cable gravtyklz Low Voltage 17 02-07-2008 04:39 PM
Cat5e cable JasontheMason Low Voltage 16 03-14-2007 11:16 PM
Cable Calc. sparkengineer21 Electrical 2 02-06-2007 07:01 PM
