Nec
Old 12-20-2007, 09:48 AM   #1
pennco tech's Avatar
Trade: electrician
Nec
i just entered school to become an electrician and was wondering if the nec will answer just about any question ill come across in the feild?
pennco tech is offline
Old 12-20-2007, 09:58 AM   #2
Banned For Life's Avatar
Trade: Super Electrician
Re: Nec
Not entirely. The NEC is a set of rules intended to ensure public safety, but the problems an electrician is likely to encounter are not code related. Electricians must perform installations that meet the customer's expectations, can be done economically and are code compliant.
Most problems are technical or mechanical in nature, that's where experience comes in. It takes years of experience to solve installation problems, once you have chosen a solution, now you must use your knowledge of the NEC to make sure your solution is code compliant.
Good question.
Banned For Life is offline
Old 12-20-2007, 12:27 PM   #3
220/221's Avatar
Trade: electrician Phoenix AZ
Re: Nec
I think you will find that it poses quite a few questions as well.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
