Multi-wire Circuits
Old 01-07-2008, 08:34 AM   #61
donaldekliros's Avatar
Re: Multi-wire Circuits
Mark Twenhafel:
Last edited by donaldekliros; 01-10-2008 at 04:40 PM. Reason: To delete multiple entries of the same message
donaldekliros is offline
Old 01-10-2008, 04:56 PM   #62
[QUOTE=jproffer;310729]Not to be argumentative, but that's absolutely...180°...100%...wrong.
The hots MUST be on opposite phases and have means to be simultaneously disconnected. This way the nuetral only carries the difference between the loads. If both hots were on the same phase, it would carry the sum of the loads and (possibly...maybe even likely) be overloaded.
NOT SO.
From Northernboy's Schematic: If you draw a line loop from Leg B to the neutral & then another line loop from the Neutral to Leg A you will note that the current in the neutral is the difference between the two legs. The current from Leg B thru the neutral is going downward. The current from the Neutral to Leg A is going upward. Therefore the current in the neutal leg is the difference between the two leg currents.
The circuit from Leg B to Leg A is indeed ONE Phase. NOT MULTIPHASES.
donaldekliros@msn.com
Wire balustrades karma_carpentry Decks & Fencing 11 09-17-2007 06:10 PM
safe hot wire driver Electrical 13 05-12-2006 11:18 PM
Standard way to wire lighting circuits robertc65 Electrical 9 03-08-2006 02:18 PM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
Using 12/3 to power Two Circuits robertc65 Electrical 18 02-16-2006 12:26 AM
