Multi-wire Circuits
Old 11-01-2007, 02:17 AM   #41
220/221's Avatar
Trade: electrician Phoenix AZ
Re: Multi-wire Circuits
(3) 3-conductor romex being pulled to a half-hot receptacle (I'm still not convinced that this is a MWBC. It still seems like two separate circuits, to me.)
I'd say not MWBC. It's two legs of the SAME circuit.
Branch Circuit, Multiwire.
A branch circuit that consists of two or more ungrounded conductors that have a voltage between them, and a grounded conductor that has equal voltage between it and each ungrounded conductor of the circuit and that is connected to the neutral or grounded conductor of the system
On a switched outlet there is no voltage between the ungrounded conductors...right?
220/221 is offline
Old 11-01-2007, 04:08 PM   #42
Fentoozler
Celtic's Avatar
What would be the point in running a 3-wire from a panel and NOT utilize 2 conductors for 2 different circuits?
Where are you heading?
Celtic is offline
Old 11-01-2007, 04:51 PM   #43
220/221's Avatar
Uhhh...read the quote that prefaced my post.
I thought I was clear?????
220/221 is offline
Old 11-01-2007, 06:13 PM   #44
Fentoozler
Celtic's Avatar
If you were clear, would I be asking for clarification?
Celtic is offline
Old 11-01-2007, 07:16 PM   #45
220/221's Avatar
I clearly clarified my clarification?
220/221 is offline
Old 11-01-2007, 07:18 PM   #46
Fentoozler
Celtic's Avatar
No you haven't....what has MWBC got to do with a switched outlet?
Celtic is offline
Old 11-01-2007, 09:15 PM   #47
GSE's Avatar
Trade: Electrical
Originally Posted by Mark Twenhafel View Post
Hi --
I'm new to the trade, have begun reading the 2008 NEC (my boss bought it and made me pay for it), and I'll be having questions as I read it. I hope I can just post my questions here. Thanks.
The code book is something you use as a reference, It was not ment to be used as a study guide.
GSE is offline
Old 11-02-2007, 12:06 AM   #48
220/221's Avatar
Celtic.
I was quoting Mark and explaining why a 3 wire to a switched outlet was not a MWBC.
I don't know why it was so hard to understand but I hope it's all good and we can sleep well tonight.
220/221 is offline
Old 11-02-2007, 05:49 PM   #49
mickeyco's Avatar
Trade: Squirrel Handler
Actually it's a great study guide if you are taking an exam to get an electricians license, all the questions come from it. It's also packed with all types of electrical mumbo jumbo and some of the code books have nice pictures.
mickeyco is offline
Old 11-02-2007, 06:16 PM   #50
GSE's Avatar
Trade: Electrical
The first day of code review, we had from 25, to 30 students, half of them trying to pass the code section on the state exams. I would ask them, how they prepared for the test, a number of them would say, they studied the code, then I would ask how they did, they din't do well, some have taken the code test as many as 4, or more times. the students that used it as a reference book, had a much better pass rate. It may be you have more accurate information on the subject of study skills and pass fail rates.
GSE is offline
Old 11-02-2007, 06:23 PM   #51
mickeyco's Avatar
The first day of code review, we had from 25, to 30 students, half of them trying to pass thire code section on the state exams. I would ask them how the prepared for the test, a number of them would say, they studied the code, then I would ask how they did, they din't do well, some have taken the code test as many as 4, or more times. the students that used it as a reference book, had a much better pass rate. It may be you have more accurate information on the subject of study skills and pass fail rates.
I'm not sure what you're saying, if you are taking a test on the code, I think studying and knowing the code would be a great way to pass the exam. Not only do you need to know the code, you need to be able to locate what you're looking for relatively quickly, that's where the studying helps. What exactly do you mean when you say use it as a "reference book"?
mickeyco is offline
Old 11-02-2007, 06:49 PM   #52
GSE's Avatar
Trade: Electrical
The state code section exams. are open book exams, you refer to the book, there is no need to waste time, trying to but it to memory. A good understanding of the chapters, and sections will allow you to index to the material, putting any book to menory will not increase success, in recall of the content. After we get the students to learn how to search by sections, they have a much beter success rate at passing the exams.
GSE is offline
Old 11-02-2007, 07:14 PM   #53
mickeyco's Avatar
And you get that how?
mickeyco is offline
Old 11-02-2007, 08:54 PM   #54
GSE's Avatar
Trade: Electrical
Just remember how you learned to use an index in school, simply apply the same methods, you sure don't learn if from studing the content.
GSE is offline
Old 11-05-2007, 06:03 PM   #55
220/221's Avatar
That's how it is here.
I passed mine on the first shot and I never even owned a code book
220/221 is offline
Old 11-07-2007, 06:29 PM   #56
Electrician
fridaymean's Avatar
Trade: Electrician
Not all of them are open book here. There is no state test, but one AHJ that does testing, does it closed book.
fridaymean is offline
Old 11-08-2007, 06:32 PM   #57
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
That is absolutely ridiculous.
I know my memory is not perfect, so I refer to my NEC all the time.
I think the point of the test, among other things, is to demonstrate that a person knows how to use the code book, not how good his memory is. We should be ENCOURAGED to pick up the book and check.
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 11-08-2007, 07:09 PM   #58
GSE's Avatar
Trade: Electrical
Well said!
GSE is offline
Old 01-07-2008, 08:05 AM   #59
donaldekliros's Avatar
:Mark Twenhafel:
I have read this forum on Multi-Wired Circuits. It is my expressed opinion that Northerboy & Thom are correct in their assesment of the topic.
donaldekliros@msn.com
Professional Electrical Engineer Licence 016990, State of Missouri
Last edited by donaldekliros; 01-07-2008 at 08:21 AM. Reason: To add my professional Registration
donaldekliros is offline
Old 01-07-2008, 08:18 AM   #60
Deleted
Wire balustrades karma_carpentry Decks & Fencing 11 09-17-2007 06:10 PM
safe hot wire driver Electrical 13 05-12-2006 11:18 PM
Standard way to wire lighting circuits robertc65 Electrical 9 03-08-2006 02:18 PM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
Using 12/3 to power Two Circuits robertc65 Electrical 18 02-16-2006 12:26 AM
