Trade: new home construction
Inverted Panelboard
I can't find it in the NEC anywhere, but is it OK to install a GE style panelboard upside down, for a bottom feed?
And I do electrical, too!
Re: Inverted Panelboard
240.81 is about the only thing you need to worry about.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Re: Inverted PanelboardThanks Sparky ... looks like inverted placement doesn't matter if the CBs are in the horizontal position, and the ones in this GE panel are horizontally positioned. I also just looked inside the panel itself, and a spec sticker says "if bottom feed service is required, rotate entire device 180 deg.". With 240.81 and this label, I've got some ammunition if the inspector gives me any heck about it. |
ampman
Trade: providing pathways for electrons and protons
did you cut the feeder to short???
an army of sheep lead by a lion will defeat an army of lions lead by a sheep |
No, bottom feed allowed me to come straight out of the meter base and into the panel, without any L's ... and in doing so the panel is at exactly the right height on the inside. Just convenience, more than anything. I still had to stub the wall out, but if I would have done a top feed, I'd had to stub the wall out a whole lot more to accomodate two L's between the panel and the meter base.
#6 | |
ampman
Re: Inverted PanelboardQuote:
