#21 |
Electrician
Trade: Electrical Contractor
Re: GFCI Testing
I think that is a good idea in light of this experience. So I bought a new receptacle tester with the GFCI test feature. I'll be checking both ways too.
John |
#22 |
Trade: Commercial and Residential Construction
Re: GFCI Testing
I have always used GREENLEE GFCI Circuit Tester - this product tests for leakage in the line. This maybe why it may not be tripping. I have tested GFCI's directly out of the box and had issues with leakage or wired improperly. This tool has been a good investment.
#23 | ||
Baltimore Electrician
Trade: Electrician
Re: GFCI TestingQuote:
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
#24 | |
Trade: Electrician
Re: GFCI Testing
#25 | |
Trade: Commercial Electrical Inspector
Have the paperwork in hand when you have this issue. There's been more then once that I asked for the packages /boxes that certain items come in. |
#26 |
ampman
Trade: providing pathways for electrons and protons
Re: GFCI Testing
i have a leviton model #6185 gfi tester it has the lights like a regular woodhead and also a switch with 4 pos. 1=1ma 2=2ma 3=3ma 4 =trips on a good gfi
#27 |
Trade: Electrician
Re: GFCI Testing
Check sec. 90.4 Eneforcement. AHJ or Authority Having Jurisdiction which is the inspector has the responsibility for making interpretations of the rules and for deciding on the approval of equipment amnd materials. basically he is right and you should do whatever it is he asks in order to get the inspection passed.
#28 | |
Diggin' up the oldies.
www.TigerElectrical.com |
#29 |
Trade: Electrical
Re: GFCI Testing
I am glad to see that some contractors actually have inspectors that check things out. Right now I am fixing another contractors srewups, and the inspector didn't do their job.
GFCI don't trip at all No GFCI protected shower lights. Plugs not working Just got a call today Air Conditioner was installed today and wire bad between panel and disconnect...Should be interesting Plus alot more......To much to list |
#30 |
Trade: Electrical
Re: GFCI Testing
Is this required in your area?
#31 |
Trade: Electrician
Re: GFCI Testing
depends. Recessed lights above shower do not have to be gfi protected if they have a gasketed cover with an acryllic lens over the bulb.
#32 |
Trade: Electrical
Re: GFCI Testing
Do you have a code section to support this? It sure isn't an NEC rule.
#33 |
Trade: Electrician
Re: GFCI Testing
Yeah, try 410.10 (a) and (d)
#34 |
Trade: Electrician
Re: GFCI Testing
Also check out gfi protection in code book. There is no section for the gfi protection of luminaires, only appliances and receptacles and such.
#35 |
Trade: Electrical
Re: GFCI Testing
Yeah, I am familiar with these things.
I think I was not clear in what I wrote. I don't see anywhere where it says anything about GFI protection and having a gasketed cover with an acrylic lens over the bulb. According to the strict letter of the code you can have an open lamp recessed light directly over the tub with NO GFI protection as long as it is not "subject to shower spray".
#36 | |
In the learning
Just take it back to the place in which you bought it, with a receipt to show proof of purchase and then swap it out so you don't pay for a new one when you don't have it. |
| GFCI breaker | seattle_sparky | Electrical | 24 | 01-25-2009 11:38 AM |
| GFCI Master not tripping | Mark Twenhafel | Electrical | 17 | 02-03-2008 06:08 AM |
| gfci and bathroom outlets | 72chevy4x4 | Electrical | 9 | 11-24-2007 09:11 PM |
| GFCI breaker vs GFCI Receptacle | gravtyklz | Electrical | 14 | 10-20-2007 05:33 PM |
| Double GFCI Problem Or No? | CGofMP | Electrical | 2 | 01-26-2006 09:43 PM |
