tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Bonding A Pool
Old 05-10-2013, 09:02 PM   #1
Techie Eric's Avatar
Trade: Electrical Engineer
Bonding A Pool
I need to bond a pool and the pool builder has baurried the niches and skimmer before I could get to them, but he assures me they are all plastic. Is it possible that these skimemrs and niches do not require bonding?
Techie Eric is offline
Old 05-11-2013, 08:02 AM   #2
Thom
thom's Avatar
Rewards Points: 4,748
Re: Bonding A Pool
You bond all the metal parts. The skimmer for sure would be plastic, the wet niche on the light is probably plastic. You should be good.
Why didn't you just look at the skimmer and the light niche from the inside of the pool area? That would answer your questions.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
Old 05-11-2013, 06:19 PM   #3
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Re: Bonding A Pool
We have to bond to the skimmer or somewhere in the water line so the water is bonded. It is around $45 for the plate to bond to in the skimmer. Just drill a hole in the skimmer and poke the stud through that is welded to the plate. Both sides have o-rings to prevent leaks. Then bond to the stud. Otherwise you can buy a stainless fitting that has the stud welded to it that goes in line at the pump and you can bond to that. That fitting is around $135 last i checked. If the pool has a light the inspector may allow the bonding of the light to "bond the water". If memory serves me you need 40 square inches of water bond, i may be wrong.
woodchuck2 is offline
Old 05-11-2013, 07:27 PM   #4
Re: Bonding A Pool
Thanks guys.
I think I'm good. The pool builder has yet to install the ladder so my bond to the water will covered by this.
I plan on using DB rated split bolts for bonding to the rebar in the deck and pipe grounding clamps for the fence, but am unsure on how to bond to the diving board. Do I simply put a ring lug on the mounting bolts?
Old 05-11-2013, 10:36 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,695
Re: Bonding A Pool
Can't say I ever met an engineer who actually does hands-on work with the project, let alone having to ask for advice from those who are normally tasked to do so. I'm curious as to how you've arrived in that position.
Tinstaafl is online now
If I have a California c-53 license (Swimming Pool Contractor) PoolRepairsOnly Contractor Licensing 1 12-10-2012 11:23 PM
Question on compacting soil around a pool BCConstruction Masonry 14 09-26-2012 05:38 PM
Local SEO NickWasHere Marketing & Sales 48 04-01-2010 06:48 AM
