Basement Wiring
Old 05-04-2008, 04:55 PM   #41
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Basement Wiring
Originally Posted by rch View Post
Can you please now cite the definition of 'Protection from Physical Damage'?
No. You already know this.
And then cite the code indicating that an unfinished basement wall in a residential 1 or 2 family dwelling is a likely location to be subjected to physical damage.
This is s judgment call. To say this is an area that is not subject to damage is a bit naive in my opinion.
I would also like to ask if any Electrician here has ever used a running board to bring Romex down the wall of an unfinished basement to a utility receptacle or light switch.
No.
PS: I hold all 3 IAEI Certifications and my employment was with the NY Board of Fire Underwriters. I left the NYBFU one year ago next week. My knowledge and experience is very current and my argument still stands that the use of Sched 40 in an unfinished Basement is NOT PROHIBITED by the Code.
It's not at all prohibited. It's just Sch40 is EXPRESSLY not rated for protecting NM from physical damage. Physics aside. I am talking about in the eyes of the NEC.
Besides, you know as well as I do that we do NOT follow the NEC for one and two family dwellings in NYS.
When I quote codes on boards like this one I use the NEC, unless of course the poster is in NY .
Speedy Petey is online now
Old 05-04-2008, 05:48 PM   #42
mdshunk's Avatar
Re: Basement Wiring
....my argument still stands that the use of Sched 40 in an unfinished Basement is NOT PROHIBITED by the Code.
Of course it's not prohibited. Unless, of course, your reason for using it was to protect against physical damage. If protection against physical damage was your reason for using it, it's simply not rated for that use. If you just felt like using it for any other reason besides physical protection, it's certainly not prohibited.
I can just barely belive that in 2008 this is even a matter of contest.
mdshunk is offline
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
Wooden Basement? LWF Construction 21 05-08-2006 04:17 PM
Garage - Protecting wiring installation eastment Electrical 1 11-22-2005 02:52 PM
Landscape solution to basement moisture problem RJC Construction 3 11-21-2005 01:34 AM
