tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
AFCI Breakers
Old 12-29-2016, 03:24 AM   #1
Finelli, A's Avatar
Rewards Points: 30
AFCI Breakers
The new code sounds like these breakers are basically required for the entire house now is that correct? I'm working on a house right now, brand new and I'm finishing the basement before they move in, and there are some in the panel box but not every circuit, so I'm wondering if I need to use them for the two runs of receptacles I'm running...thanks for the clarification
Sent from my SM-G900V using Tapatalk
Finelli, A is offline
Old 12-29-2016, 08:21 AM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 880
Re: AFCI Breakers
Sounds like a question you need to be asking your electrician.
Randy Bush is online now
Old 12-29-2016, 08:28 AM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,410
Re: AFCI Breakers
More to the point... the electrician is the one who should know and be doing this.
Why is there not a Flat Mars Society?.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
Randy Bush (12-29-2016)
Old 12-29-2016, 08:31 AM   #4
Randy Bush's Avatar
Rewards Points: 880
Re: AFCI Breakers
Well yes what I meant , just did not say.
Old 12-29-2016, 10:14 AM   #5
Finelli, A's Avatar
Rewards Points: 30
Re: AFCI Breakers
It's not rocket science fellas, just asking a question on the new code, that's what this forum is for, if you don't have an answer to the question keep your opinions to your self.
Old 12-29-2016, 12:20 PM   #6
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 654
Re: AFCI Breakers
Its not a "new code" and this forum is for professional contractors helping each other. No offense, but you don't sound like an electrician and the electricians on here aren't likely to advise you on a public forum what to do.
There is a sister site called DIY chat room that would be a better place to ask your question.
http://www.diychatroom.com/#/?_k=x7zsjb
Xtrememtnbiker is offline
Old 12-29-2016, 12:37 PM   #7
Finelli, A's Avatar
Rewards Points: 30
Re: AFCI Breakers
I'm not an electrician, I'm a carpenter who is in the middle of finishing a basement. I ask because the last apartment remodel I finished in September, the electrician put in a new service and there were no arch fault breakers and the electrical inspector passed the box, but I know shortly after that the new NEC code came out along with the international building code and as I read it I didn't notice it was from 2014. I was just looking for clarification. I don't appreciate it when people take the opportunity to insult me for asking a question I have helped plenty of plummets, electrician, hvac, sheet rockers with carpentry/building questions, we're all contractors.
Old 12-29-2016, 12:55 PM   #8
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,883
Re: AFCI Breakers
No offense, but electricians and plumbers tend to be a bit snotty about sharing info on their trades compared to other specialists.
New York state, like PA, does not require licensing to do electrical work. It's very common for GCs to do that sort of thing in-house.
Finelli, even under the '08 NEC, most likely your inspector is going to want AFCIs. They're pretty much required in all "living spaces".
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Finelli, A (12-29-2016), Xtrememtnbiker (12-29-2016)
Old 12-29-2016, 01:44 PM   #9
Finelli, A's Avatar
Rewards Points: 30
Re: AFCI Breakers
Thank you sir, I appreciate it !!
Old 12-29-2016, 02:11 PM   #10
Rewards Points: 654
Re: AFCI Breakers
I'm aware of that. It's why I said what I did regarding them not being likely to share their knowledge.
I didn't know that New York doesn't require having an electrical license. That seems odd to say the least...
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Tinstaafl (12-29-2016)
Old 12-29-2016, 02:14 PM   #11
Finelli, A's Avatar
Rewards Points: 30
Re: AFCI Breakers
A license is required in certain counties around albany and south, my business is located north of there.
Old 12-29-2016, 02:26 PM   #12
XJCraver's Avatar
Trade: Building Official
Rewards Points: 214
Re: AFCI Breakers
IL doesn't require any State-wide licensing either. Some municipalities do. It gets interesting working from town to town.
Finelli, A - NFPA has all their codes available to view for free on their website; go here:
http://www.nfpa.org/codes-and-standa...es/free-access
The '14 NEC requires afci's almost everywhere in a dwelling unit.
XJCraver is online now
The Following User Says Thank You to XJCraver For This Useful Post:
Old 12-29-2016, 04:45 PM   #13
480sparky's Avatar
Re: AFCI Breakers
....... I was just looking for clarification. I don't appreciate it when people take the opportunity to insult me for asking a question I have helped plenty of plummets, electrician, hvac, sheet rockers with carpentry/building questions, we're all contractors.
It's not a black or white issue. There is no "Yes, all circuits are required to be AFCI'd" or "No, you don't need to use them" answer.
Your original question is quite ambiguous when you refer to 'new houses' yet you're finishing off a basement. If the basement has already been wired to Code, and it didn't require AFCIs back when that was done, and the current wiring will pass as it is, then no, you won't need AFCIs.
But if you're going to start running more rope, then maybe you do. A lot depends on your AHJ (which is who would be best to ask about this).
If you want one single, one-size-fits-all answer: Depends.
SLSTech (12-30-2016)
Old 12-29-2016, 04:51 PM   #14
Finelli, A's Avatar
Rewards Points: 30
Re: AFCI Breakers
My question spelled out exactly what the situation was but I've got my answer already from those not looking to stroke their ego, have a nice day.
Old 12-29-2016, 06:27 PM   #15
Framer53's Avatar
Trade: Handyman
Rewards Points: 338
Re: AFCI Breakers
Before everyone gets bent out of shape because we have no statewide licensing laws for any part of construction, in the electrical area before the power company is allowed to turn the power on we must have an independent inspection.
Framer53 is online now
The Following User Says Thank You to Framer53 For This Useful Post:
Old 12-29-2016, 07:01 PM   #16
480sparky's Avatar
Re: AFCI Breakers
My question spelled out exactly what the situation was .........
Yes, ................... after 2 posts.
Old 12-29-2016, 07:40 PM   #17
Finelli, A's Avatar
Rewards Points: 30
Re: AFCI Breakers
What ever bud lol , thanks for the help fellas I appreciate it
Need help with square d homeline fuse panel box and the new afci breakers Tweed11 Electrical 10 11-18-2013 11:01 PM
Inspector says breakers gotta be replaced? Bigb142 Electrical 4 12-19-2011 07:46 PM
AFCI Protection porject in class electrichelper NEC Discussion 2 07-14-2009 06:31 AM
